Re: Is it just me….
Beginning to realise the importance of finding out just what is required before starting a recon. I have been asked to supply a load of cheap machines for foreign workers on contracts in the local factories. I had picked up a Hotpoint 9545 for this purpose. I had gone to deal with a ” not spinning” fault which turned out to be the belt come off due to wobbly drum bearings. As the machine was 15 years old the customer decided not to get the bearings done but buy a new machine and give me the old one.
I stripped the drum, put new bearings in but also found the bronze bush was cracked on the spider. I found another spider, put that in, drum as wobbly as before. Take a look at replacement spider and find the front bearing has been turning on it, hence the play. Raid another machine for a 3rd spider which is OK.
Start putting the belt on and realise that the rear motor bearing has also failed. Find another motor I can raid for an armature, put it all together, no motor action. Get the meter out, motor TOC open circuit. Motor to bits again for a replacement TOC. How can a TOC fail the same time as the belt is falling off? 👿
