ISE Ci555 leaky
Viewing 15 posts - 1 through 15 (of 23 total)
  • #82181
    ceedy
    Our ( now getting on a bit) 555 has got a small leak.. in the drum.
    it seeems to be right on the join next to one of the motor mount lugs .
    Nb .. this is the first time I’be been under the washer , everything else ( quite a few ) has been done under warranty . but now we are in
    the wilderness 😆 ..
    I have noticed that right next to the leak there is a drum bolt missing..
    Not having one of these “specials” its now got a 5mm nut & bolt in there. but not made a lot of difference..
    So.. down to the questions .. being an Ex aircraft mech eng , got a bit of a clue 😉 ..
    Is the drum just a face to face joint or is there any kind of seal/o ring ?.
    And what the best procedure for getting the whole unit out of the casing ?? .. while I still have the strenght and inclination :rolls: 😆 .
    cheers
    Chris
    #419042
    Re: ISE Ci555 leaky
    Has a neoprene rubber seal between the front and back tub halves. All comes out the front to access. Have fun! 😀
    #419043
    Re: ISE Ci555 leaky
    NB. There is no bolt missing, there is one hole for a bolt that is not actually used or needed on this machine.;)
    #419044
    ceedy
    Re: ISE Ci555 leaky
    Thanks for that ..
    It only seem to leak during certain cycles,
    the ones when I’m not sitting watching .. :rolls:
    wondering whether its actually a Crack somewhere around the motor LUG that opens up when the motor is loaded..
    getting stuck in today , as too busy yesterday .with school and MOT’s.
    Oh ! the pressure from her ?? 😆
    Silly question but worth asking before 😳 … is there a sequence of panel removal to get in ?.
    Does the front panel just come off for access ?, will found out though when I get in there . our wash room is bit small so got limited access.. 🙁
    thanks
    Chris
    #419045
    Re: ISE Ci555 leaky
    You might want to take it out of the wash room then to work on it.
    #419046
    Re: ISE Ci555 leaky
    The drum seal Martin mentions is a well known cause of leaks after a few years, will be more likely to leak on hotter, longer washes.
    Not an expensive part but a major strip down involved.
    #419047
    ceedy
    Re: ISE Ci555 leaky
    Is this seal even slightly visible for mthe outside. 😉
    As just looking at ours, unless the seal is microns thick? 😆
    I can’t see one there??
    Quite a bit of grey cruddy residue around the joint line in odd places
    Cleaned up and can’t see any cracks visible.
    already Sussed out how it comes apart. 😳
    Anyone used addition/alternative methods of sealing ?
    got rather a lot of stuff, from my years keeping a 36 yr old Fiat X1/9 alive and on the road 😆
    Chris
    #419048
    Re: ISE Ci555 leaky
    You can’t see the seal as it sits in a recess.
    #419049
    Re: ISE Ci555 leaky
    THIS is the part you need. Much better to change it rather than attempt to seal the drum with adhesives or sealants given the amount of work involved in getting at it. 😉
    #419050
    ceedy
    Re: ISE Ci555 leaky
    Got a seal and pump ( a bit rattley) on Order..
    C.
    #419051
    ceedy
    Re: ISE Ci555 leaky
    Piece of Peewee to work on innit… 😉 😳
    Reckon will have a peek at the motor brushes while its in bits 😉
    Chris
    #419052
    Re: ISE Ci555 leaky
    I have done that seal change quite a few times and do it without removing the whole drum from the machine.
    Carefully lie it on its back and with the right tools it is possible to remove the drum front without taking the whole drum out. 😉
    #419053
    ceedy
    Re: ISE Ci555 leaky
    exactly what i’ve done.. 😳
    Spent more time cleaning out all the moulding recesses of goo/gunk/scale . 😆
    C.
    #419054
    Re: ISE Ci555 leaky
    You need to read THIS 😉
    #419055
    ceedy
    Re: ISE Ci555 leaky
    iadom wrote:You need to read THIS 😉
    Ahh.. another page … been looking at loads of other peeps ways of cleaning out gungy bits … and all the various concoctions to clean things out . 😉
    Some of ours needed a good poking to shift and left the other odd bits soaking while waitingfor the part to arrive. ..
    cheers
    Chris
