ISE W256W Thermistor tripping RCD
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ISE W256W Thermistor tripping RCD
  • #89903
    snikom
    Hi There
    I have an ISE W256W
    For some weeks now it has been tripping the RCD intermittently.
    I have had the back off several times but as my wife pointed out it always cured itself after 3 days no matter what I did, or indeed if I did anything.
    Today through a combination of skill and luck I have managed to track it down to the thermistor. So I nagged my wife about overloading and started to put things back together.
    On removing the thermistor it was wet, I dried it off, replaced it in its housing and powered up all was good. So I unplugged and clipped in the switchboard at the front (Which I had removed) on plugging back in the rcd immediately tripped again. If the thermistor is left away from the drum all is good as soon as it makes contact it trips.
    Any and all advice gratefully received
    #442951
    Re: ISE W256W Thermistor tripping RCD
    from what u say thermistor has a short to earth
    needs replacing
    Thermistor is a low voltage component. That can’t short to earth or enough to take out an RCD as there’s only 12V DC running through it IIRC.
    Water getting down there and onto the motor though…
    snikom
    Hiya
    Thank You for the replies
    I ordered a new thermistor yesterday after confirming the machine would power on with the thermistor out of position but trip when in situ or in contact with the drum.
    No signs of water on the motor or indeed anywhere apart from on the thermistor.
    Things were working again this morning (thermistor dried out I presumed) so I tried a cycle.
    It seems the machine is tripping during the spin cycle and having just tested it the thermistor is wet again, with a small load.
    We wash at low temperatures normally so I am thinking my next step is, check for blockages at drain level and perform a maintenance wash.
    This bring me to two thoughts
    1. The spin is very loud and has been for some time, before things went pair shaped for ise it was repaired by having the springs which attach the drum to the case at the top replaced as they had failed completely (I found one last week in the bottom of the machine). But the spin remained loud. There is damage to the back panel where the motor was or is hitting the casing. Could the spin be out of balance and thus sending water where it shouldn’t go?
    2. Could it be that water isn’t getting drained as quickly as it needs to and is backing up therefore being forced out onto the thermistor?
    Thanks again
    Chris R
    #442954
    ah that makes more sense
    check just below the pulley sounds like you bearing system is failing and the water seal is letting water through that is leaking on the thermistor
    snikom
    Thanks Again
    Checked the belt and motor and drum bearings. Now I am not a mechanic but in car terms I would have said they were all absolutely fine. No movement and no untoward sound.
    Trying a maintenance wash now.
    *Update from maintenance wash*
    1. Spin is a lot quieter when empty, pulley wheel at back is unbalanced though.
    2. Water either isn’t heating at all or not very much
    3. Thermistor wasn’t flooded
    #442956
    snikom
    Just done a proper wash, sheets on normal wash 1900 spin
    There is evidence of leakage on the outlet and a slight damp patch underneath. Looks like its time to take the front off too as I can’t observe where the leak is coming from with the motor in-situ and can’t spot it with just water in the drum and the motor out, I am guessing leakage whilst spinning but I am quickly getting out of my depth 🙂
    #442957
    Some info that might help if you read through them…
    http://www.ukwhitegoods.co.uk/help/fix- … g-machines
    http://www.ukwhitegoods.co.uk/help/fix- … ap-drawers
    Look for telltale run marks.
    snikom
    Thank You K
    Water is leaking from breather hose, run marks down that side of drum.
    Am I correct in thinking the best/only cure for this is educating the user? If so I may be doomed 🙂
    #442959
    snikom wrote:Am I correct in thinking the best/only cure for this is educating the user? If so I may be doomed 🙂
    Pretty much I’m afraid.
    snikom
    All seemed fine, no sign of leaks from the breather hose, put machine back together blew an ic (possbily power ac/dc converter chip) on the control board, thermistor was wet again but don’t know if this was the cause or I had trapped a cable or similar. Gutted 🙁
    #442961
    Charliedurrant
    Hi,.
    I have and ISE 1604 w and after changing the water pump and cleaning the control panel, while pushing the control panel back in place the AC DC regulator chip pressed on a screw, cracked and blew.
    It’s a 50p part and easy to solder. In my case it was a 7 pin chip LNK363PN.
    Maybe the same, maybe not…
    #442962
    snikom
    Thank You Charlie
    It is a 7 pin chip but I can’t idea it as the whole top has blown off.
    I am tempted to just solder on another regulator on the nothing to lose basis and a part number is really helpful, it may well be worth the punt if I can’t find out the “correct” chip
    #442963
    Martin114
    The W256W chip is the same as charlie’s 1604W – LNK363PN
    #442964
    Charliedurrant
    Here’s the 7 pin part
    http://uk.rs-online.com/web/p/intelligent-power-switches/0533812/
