ISE10 1606W problem – any ideas?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ISE10 1606W problem – any ideas?
Viewing 4 posts - 16 through 19 (of 19 total)
  • #443679
    jise1606w
    Re: ISE10 1606W problem – any ideas?
    UPDATE – The wash completes on a Synthetic setting but not Coloured or Quick, so no idea why that would be but my feeling is it has to be a PCB error
    #443680
    jise1606w wrote:It drains, although slowly. So. . .
    I think you’ve now told us where the fault lies then. 😉
    #443681
    EFS
    Dismantle drain pump and look for coin or button.
    Blow down drain hose from the pump end to make sure it is clear which will by then have covered all possible causes.
    If no luck there then get a man in.
    Steve
    #443682
    jise1606w
    SOLVED!
    Thank you for your replies – having removed and cleaned every part of the drainage system over the weekend I think I have resolved the problem. I have run three successful cycles of the washing machine with no errors.
    I think the problem was all down to a postage stamp sized piece of clear plastic wrapper which I believe was acting as a valve and was most likely sticking through capillary action to the side of the pipe or sump and resisting being flushed out.
    I appreciate all your help and suggestions – there is one final request if anyone can help:
    I would like your help to source the clips that Asko fit on their washing machines because I have had to remove the ones already fitted (I had to cut them) and replaced them with jubilee clips which seem to work but are thicker than the manufacturer fitted hose clips. Can anyone tell me what they are called and a UK supplier?
