ISE2 Technical Manual
Viewing 15 posts - 1 through 15 (of 19 total)
  • #33070
    Hi guys,
    I did the manual today for the ISE2 which should hopefully help you if required. It’s not as complete as perhaps I would like it to be but it does have most of the important stuff in it.
    You can access it from the technical area of the ISE website or use this link to have a gander. It takes a bit as it’s a 4Mb PDF file with all the images in it.
    Re: ISE2 Technical Manual
    Downloaded in a flash. 🙂
    Just printing it out now. I notice an Auto Test programme, I don’t seem to be able to find how to run it. ❓
    Notice in the parts list it has a parasite filter. 😆
    I did say it was info from factory, I didn’t have time to rewrite it all the way I’d perhaps like. 😉
    I will add the test routine to it ASAP, but I had to start to get the show on the road, after all the machines have been about for almost two months. But it’s better that nadda IMO and I’m trying to get it there as quickly as I can, even if it’s not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} to my satisfaction.
    It is a very good start, much appreciated, I just wonder which parasite they are hoping to trap in the filter. 😆
    I know nuffin’ about parasites… well perhaps one.
    The parasite filter is apparently the mains filter. 😆
    #237325
    Goatboy
    iadom wrote:The parasite filter is apparently the mains filter. 😆
    #237326
    Updated with the test program details as well as a few other bits and bobs. 😉
    I did it so you you could just print off the new pages if required.
    Thank you. 8)
    #237328
    bazza500
    Front cover says “Version 1.0 December 2008.
    Bloody hell that was a quick year. 😆
    #237329
    Well, I repaired my first Vestel machine today. Tripping cricuit breaker, turned out to be a faulty mains suppressor. Had a matching unit in the van, so fitted that and it powered up but wouldn’t start. Fortunately the neccessary info was in the ISE2 manual and managed to force a re-set and away it went.
    This was a Ballack BAL1000W, btw :rotfl: .
    All’s well that ends well.
    Del
    BTW did you find any parasites in it Chris ? lol
    Sean
    #237333
    Its a good job it wasn’t a Shevchenko £20,000. 😆
