Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Jockey pulley burning out on Hotpoint/Indesit dryers
- This topic has 27 replies, 9 voices, and was last updated 9 years, 4 months ago by
grooster.
October 22, 2017 at 2:41 pm #442907
ModeratorRe: Jockey pulley burning out on Hotpoint/Indesit dryers
I wonder if they are still using them for the large load models?
October 22, 2017 at 3:25 pm #442908Grendal
ParticipantRe: Jockey pulley burning out on Hotpoint/Indesit dryers
They use the bpm motor on the higher end machines as it has a soft start They have been in use for at least a couple of years
October 23, 2017 at 2:42 pm #442909Simon46
Ive done one of these. Out of warranty. It pulled the plug out of the motor.
Oddly enogh im doing a ctd80 tomorrow after recall done and fitting the new white wheel.October 23, 2017 at 5:14 pm #442910rolf
Found model number on invoice. SUTCD97B6GM.
9 kg.October 23, 2017 at 5:39 pm #442911Simon46
Thats the breed. Bit more of a pig to do as the belt was shredded
October 23, 2017 at 6:15 pm #442912iadom
:tup:
Would be interesting to see serial number as that model was introduced in July 2014.
October 23, 2017 at 6:36 pm #442913rolf
Gone as far as I can, but the machine is still available at Tesco. Like you said it’s probably just for the large load stuff.
October 23, 2017 at 7:16 pm #442914iadom
Digging further it is based on the Aqualtis dryer range, pulleys different to the early dodgy ones as far as I can see. 🙂
October 23, 2017 at 7:30 pm #442915iadom
Again a bit OT but found another bit of info that may be useful, it appears there is a kit to repair the drum shafts on the riveted drums now.
October 23, 2017 at 7:33 pm #442916Simon46
Do you need drill dremel grinder. Never done one
October 23, 2017 at 7:37 pm #442917Hollytree_Technical
That kit has been around for a while and I have fitted quite a few, you just use a 6mm drill bit to drill out the 6 rivets and bolt the new shaft on, easy job with no grinder required.
Jem
October 23, 2017 at 8:00 pm #442918Simon46
Cool. Ta Jem
October 24, 2017 at 10:42 am #442919rolf
Yeah, done a few as there all pressed on now. Bit more fiddly than the three screw version, but straight forward.
