John Lewis Heat Pump flashing “dryer cycle” sign
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum John Lewis Heat Pump flashing “dryer cycle” sign
Viewing 8 posts - 16 through 23 (of 23 total)
  • #483590
    ec362
    Not yet. Where do I find those? Thanks so much for your help
    #483591
    ec362
    Aha. The connections of the wiring look sound (as much as my untrained eye can tell). But I can see one of the wires appears to have taken an impact of some kind as here https://drive.google.com/file/d/1Sxz4qg_6E_fPUrcrMwfoYbnD84yDieHM/view?usp=sharing
    Presumably this would be the issue. Can I strip and reconnect these or does it need something more substantial?
    #483592
    ec362
    Looking more carefully, the broken one appears to be going from the PCB control module at the top of the machine all the way down the side of the machine to the motor assembly, then into the motor through a junction box
    #483593
    ec362
    Hi Dave. Don’t know if you have any more thoughts but I’ve stripped the wires that were cut/nearly cut and attached them again. I’m still unfortunately getting the clicking sound from the control module at the top of the machine, and no movement at the motor. Any final thoughts or am I right in thinking I probably need to ditch… thanks
    #483594
    my next job would be to check the motor windings for continuity
    if ok
    check pcb relays for bad solder joints
    ec362
    Thanks Dave. I will check the continuity. The PCB relays may be more of a challenge as I don’t have the manual/diagrams. Do you have a link for this? Cheers
    #483596
    your not looking for diagrams
    find the relays and check all solder joints
    bought a faulty AEG dryer off ebay some years ago for £8 and one bad solder joint in the motor circuit stopped it
    ec362
    Ok, will do.Thanks Dave, will come back when I know!
