John Lewis JLWM1203 drain pump error
Home Forums Public Support Forums Help And Support Washing Machine Help Forum John Lewis JLWM1203 drain pump error
Viewing 5 posts - 16 through 20 (of 20 total)
  • #410511
    mooncalf
    Re: John Lewis JLWM1203 drain pump error
    morning,
    just put the new pump in..
    tried running a cycle on the machine and its just making a buzzing noise???
    any ideas??
    got down to floor level and it sounds like the pump is trying to turn over (or is turning over..)
    thanks
    Craig
    #410512
    mooncalf wrote:got down to floor level and it sounds like the pump is trying to turn over (or is turning over..)
    At floor level and with the filter removed you can easily see if the pump is turning. The Impellor spins at several hundred r.p.m.
    #410513
    Andy jones
    Wi always sound a bit strange until there’s water in it. Try a wash cycle then pump out
    #410514
    mooncalf
    hiya,
    the impellor is definitely working.
    tried setting it on spin cycle and no drum movement but the clock counted down on the cycle.
    tried setting it on a quick wash and again can hear the pump working but no drum movement and no water fill I dont think..
    cheers
    craig
    #410515
    Motor brushes are knacked then. Check the motor.
