Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Matsui M12FDW09 Dishwasher
- This topic has 23 replies, 5 voices, and was last updated 11 years, 9 months ago by
Sandford.
July 15, 2014 at 7:18 am #416349
ParticipantRe: Matsui M12FDW09 Dishwasher
Sandford wrote:Could this piece of kit be faulty or do I continue looking for thermostat?
Can we just ask why you’re asking about the thermostat in the first place? Would it not be better for you to tell us what exactly is wrong with your dishwasher? The symptoms perhaps?
July 15, 2014 at 8:00 am #416350Sandford
when washing dishes the water cycle is cold and they are not getting dried. Having looked through the forums they mentioned the thermostat and heater. I have already replaced the heater and the water is still cold so looking at thermostats as next element
July 15, 2014 at 9:08 am #416351Martin
Oh OK. Well as I said earlier, it looks like an NTC screwed into the sump. You might like to measure the resistance of that (on the Kohms scale). Maybe the thermostat is inside the door panel? (I can’t see it in your photos and judging by the black plastic fitting on the Matsui web site it may well be in the door around the control panel area??)
July 15, 2014 at 9:23 am #416352Sandford
Just stripped the door panel and nothing in their apart from the main PCB, it is a mtstery, What reading should I get across the NTC?
July 15, 2014 at 10:15 am #416353appliancefix82
In photo 1 you have a clear shot of your heater just to the right of the wiring you have a white plastic switch fitted in the black hose, this is your heater pressure switch, generally the diaphragm in these becomes blocked and won’t allow the heater to switch on.
I used to work for Currys as a TSM and these were quite a common partJuly 15, 2014 at 12:15 pm #416354Sandford
Thanks will check that out also
July 15, 2014 at 4:10 pm #416355Sandford
part removed and looking clean, does anybody know if this model does have a thermostat or should I be testing the TOC? if so does anybody know what the reading should be across it?
October 6, 2015 at 4:16 am #416356alicat
Hi guys new to the site i am in the same situation, i cannot find the thermostat (Sanford) did you find the part
October 7, 2015 at 7:18 am #416357alicat
Anyone on any info on where the thermostat is located, have seen the part on various websites, but nothing resembles the part, looked everywhere for it
