Memership ID number…
Viewing 15 posts - 1 through 15 (of 19 total)
  • #55392
    VillageIdiot2
    Blocked
    Jim has a point (In the members area)… Have we got membership numbers?
    I wondered that earlier, but didn’t think to pick up on it…
    Ade 🙂
    #323492
    Yup.
    But I’m a few thousand miles from where I can find them out. 😉
    Lawrence
    Re: Memership ID number…
    you once sent me a scan of them that I am desperatly trying to find .
    #323494
    Steven
    Can i have a note of my number please?
    Would it be easier if our id numbers were all the same for ISE UKW WTA?
    Steven
    #323495
    Steven wrote:Would it be easier if our id numbers were all the same for ISE UKW WTA
    That was the original plan!!
    Which was scuppered by a certain person in Rotherham as he cocked it up.
    I can’t access it from here Steven and T is with me (apparently I had to bring her and the kids on hols as well) so I can’t answer it right now. David MAY[ be able to locate it but I can’t guarantee it as UKW, ISE and the WTA are on three separate systems for accounting purposes and I don’t know if he has access to the WTA one.
    Lawrence
    I now have them ,I will send a copy up to David in case he has any enquiries.
    I will answer people as they ask
    Lawrence
    #323497
    aqualectric
    Lawrence – had to change Tim Downing’s number as it was out of sequence. UKW091 is the logical follow on to UKW090. UKW80 (his original number) does not fit with the list. I looked and looked but couldn’t see a logical reason for UKW80 until the list grows to UKW80?…..ie:- 800 + members. 😉 That’d be nice!!
    He posted for his number the other day, so I gave him UKW091. Can you amend your copy please.
    Cheers,
    Steve.
    #323498
    aqualectric
    George (Allsorts) has enquired about his membership number. Problem being – he’s not on the UKW list; so I will need to allocate a new number.
    After the WTA meeting and the large number of applications, is the old list still relevant? If so, where are we in the numbering sequence? My list shows up to UKW091. 😕
    Steve.
    #323499
    I meant to check this Steve, sorry, its slipped the net, my bad.
    I’ll try to do it today.
    traceukw1
    The old UKW numbers are different to the WTA membership numbers as i had to start again due to opening up a new sage account for the WTA.
    If Kenneth doesn’t send you a copy i will try to remember when i am in work Steve.
    Once K has set up the WTA logo on sage i will get invoices sent off to the agents who paid their subs and they will then have a copy of the membership number.
    T.
    #323501
    Lawrence
    Hi Tracey not sure if K mentioned it but we made a promise that all who had applied for membership would recieve some sort of membership certificate with there member no on within a month i.e end of October as were being battered left right and centre with regard to membership applications.
    Lawrence
    #323502
    traceukw1
    K was organising the certificate side of things so he would be able to answer that one better than i can. 😉
    T.
    #323503
    Certificate I knocked up in five minutes flat with the use of a template, something like this:
    The time bit is doing them. 😉
    Any comments let me know.
    Steven
    Hi Ken
    I was working on something my self, but as you have done it you beat me to it. looks ok.
    I had similar, added at the end… adears to code of practice as set out in the wta consitution?
    If you like, I will check with Lawrence and Ade and if ok with them tag along when they were going to do the cop stuff at Kilmarnock in october and if you like I can work on that and make them up.
    Let me know guys?
    Steven
    #323505
    Lawrence
    Steven
    Sounds like a plan to me,I am going to try and book flights tonight ,that means we can get a lot done in two days . 8)
