Microwave plate turning motor broken
Home Forums Public Support Forums Help And Support Other Appliances Microwave plate turning motor broken
Viewing 10 posts - 16 through 25 (of 25 total)
  • #493659
    Junk Yard wrote:
    From memory it was 40V. But I will check it again later on
    Is the voltage the only difference in that one and the one I just bought from the “white goods” shop?
    If its the voltage being an issue, then can i just find a 240v supply from the microwave somewhere ells? and wire the plug from the motor to it? (presuming that the rest of the microwave runs on 240v)
    thats the only one i have seen thats not 230V
    how are you going to stop the motor from turning all the time the unit is plugged in
    you would need to find a switched feed
    Junk Yard
    What do you think the switch voltage is? do you think it is reduced? if so then would a relay work; using the switch power and the main 230v power
    #493661
    short answer don’t know
    relay should work but it needs to be mounted correctly and wires routed so it cannot rub or short out
    have no spec on the unit or wiring diagram
    re measure voltage
    also check meter accuracy by measuring mains voltage. was wondering if meter reading high
    Junk Yard
    i though i would test it on its own first. by wiring direct to 240v.
    Which terminals are + and – ? or dose it not matter since it is AC?
    #493663
    does not matter for AC
    Junk Yard
    i have just tried powering it direct from main power. and nothing! no turning no sound
    #493665
    what have you powered from mains power ?
    your old motor ?
    Junk Yard
    electrofix wrote:what have you powered from mains power ?
    your old motor ?
    No i have powered the new motor i just bought
    #493667
    that should work must be faulty if it does not
    Junk Yard
    I will contact them about it
