Hi, hope you don’t mind me hijacking the thread, but you seem to know your way around this model (G1022). Mine will trip out the circuit breaker about a minute after being started. I assumed it was the heater element, replaced it, which didn’t cure the fault (the resistance was the same as the original). The machine appeared dry inside with no obvious leak, is it likely to be the capacitor? I wondered if it was the pump starting up causing the circuit to trip out.
Or any thing else I can investigate? Many thanks, Steve
