Mini Candy washer pump
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Mini Candy washer pump
Viewing 15 posts - 1 through 15 (of 18 total)
  • #45329
    Never seen one of these before, old dear in a second floor flat.
    Tiny machine, looks quite old. The drain pump is leaking but I can’t seem to get one to fit. Its the old shaded pole type and none of the three or four old type pumps I have seem to be the right size, won’t fit an Askoll type pump either.
    The only model number on it is Aquamatic 3.
    The pump body looks similar to the Hoover/Candy front mounted pump but without the extra outlet hole for the pipe that goes up to the dispenser that rubs through all the time.
    She doesn’t have space for a normal sized machine, not sure if anyone makes one this small now but if they did I guess it would carry silly price tag.
    Are there any Candy pumps with only one outlet.
    Can post pics if its of any use.
    LJDomestics
    Re: Mini Candy washer pump
    Pic would be good jim… then i will have a looksy around for you too.
    #285345
    Will post it up later, the squash court beckons, 😉
    Sorry for delay, had to make the tea after my squash and there was a football match to watch. 😉
    I suppose that at a pinch I could use a Hoover Performa pump and blank off the hose outlet I don’t need.
    #285347
    LJDomestics
    looks rather simmilar to a indesit 2000?
    im certain… but was a good while ago i ordered one of these from connect.
    I think i left in the shop down south in the move up here
    bloody squash?? since when did you have time? 😆
    i will certainly try and rack my brains and do some searches to see if i can relocate on connect.
    #285348
    Only manage three games a week these days, you’ve no idea how theraputic lashing that little ball against the wall is after a day a the ‘coal face’.
    It helps me keep fit enough to lift a washer down three or four steps into the back yard or garden of a customers house on a nice day. 😛 😉 😆
    LJDomestics
    Found it… it was a performa i had not genuine either.
    would a 2000 coil not fit correctly?
    #285350
    LJDomestics
    Funny thats what the missus says about my 2 😆
    #285351
    I tried several old shaded pole type bodies but the seals are different.
    Just had a look through some old Qualtex catalogues and found one that should do the trick.
    Either a PMP224 or a CAN91941771, thats the three hose pump filter body but it comes already supplied with a bunged up hole. 😀
    Looks like PMP3413 £11.80 @ Connect. “Fits DOMINOD545 P503X 641X 861 aquamatic 570X 611X 807X 809X 811X 861X plaset 53336” If you still don’t have a Connect account, Jim maybe you can track it down from those model numbers. Or get someone else to get you one.
    Mike.
    #285353
    Thanks Mike, between us I think we will be able to keep the old girl happy. 8)
    Heh, I missed this!
    It’s the standard Plaset pink impeller pump Jim which is as cheap as chips. CY5108 from MP should fit it fine although with some you have trim a little bit off the impeller blades to stop it clipping the pump housing.
    Almost half the price of PMP3413 Mike had. 😉
    Excellent, getting better all the time, thanks K. :tup:
    Any ideas how old the machine might be, it looks all of 20 years old at least?
    Trumped! 🙁
    He must have cheated by getting the book out! 😆
    Mike.
    #285357
    Na, I’ve done a few in my time. 😉
