Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Moisture on top of integrated vanity panel immediately after opening – normal?
- This topic has 23 replies, 2 voices, and was last updated 8 months, 3 weeks ago by
bluin.
July 16, 2025 at 11:56 am #493266
bluin
Participantelectrofix wrote:take the outer door off and see if you still get steam
I’ve removed door and the problem still exists but not as excessive:
Again, during the washing cycle, I could see a slight mist on the silver protector strip on the left hand side. When I rubbed my finger along it it was slightly damp.As the machine went into the ~8minute drying cycle the steam was easily detectable with a mirror – misted up instantly.
*However, after the wash had stopped the top left of dishwasher door only slightly damp but this time the top of the stainless steal door didn’t have a build up of water. Nor was the seal dripping wet (like it was with the vanity panel fixed).
*But it was still releasing steam and i assume it will be worse once I reattach the door.
Is this an easy fix – or could it be any number of things?
As mentioned before – the machine was levelled under the counter using a sprit level inside machine. But, confident that front is level – as I measured clearance from the floor on both sides to bottom of unit and used a level on top of inside dishwasher. Level shows it as plumb).
I may go through the rigmarole of an exchange rather than a prolonged repair process – depending on what you guys think.
July 16, 2025 at 6:07 pm #493267electrofix
Moderatorno i agree with you get it replaced while you can
DaveJuly 17, 2025 at 2:26 pm #493268bluin
ParticipantThanks for all your help, Dave. I’ll ring tomorrow and arrange an exchange.
I chose the BEKO BDIN26430 as it has a fully stainless steal interior and had good reviews (plus, BEKO seem to keep parts going for years).
Are there any other makes/model you would recommend i consider if they haven’t got stock – with fully stainless interior?
Or are they all much of a muchness after certain price apart from useless bells and whistles (£400)?..
* I can spend more – but I’m only interested in short washes (wife swills dishes) and don’t use/need the auto open door function. Plus, i’m not keen on trusting a machine to hold a tank of water for a couple of days for eco reasons. When they have the ability to leak in many other ways 🙂
July 17, 2025 at 7:26 pm #493269electrofix
Moderatormay just be a bad one
just fitted one tonight , no problems as far as i can see
DaveJuly 17, 2025 at 11:29 pm #493270bluin
ParticipantThanks, I’ll stick with same model.
Did you have any issues with the back leg’s mechanism slipping when turning?
One thing i forgot to mention is, unlike my old machine, the door on this machine didn’t virtually close when you let go about half way up. It would hang about 6 inched open. Is this the norm because of the auto shutting? Or, was this another fault?
*I don’t suppose you live in Devon? I would trust you to fit it properly.
July 18, 2025 at 12:32 am #493271electrofix
no unfortunately Liverpool
you can adjust the springs on the door as some outer doors are heavier than others
back legs … i always find the best way to adjust is to tilt unit forward to take the weight off them. The way the system works is the legs have to turn and that much harder with the weight on. So raise front legs then open door and let the unit hinge on front legs lifting back legs up so you can adjust. Never force them
DaveJuly 18, 2025 at 8:01 pm #493272bluin
Participantelectrofix wrote:no unfortunately Liverpool
Shame – you do things correctly with experience.
electrofix wrote:you can adjust the springs on the door as some outer doors are heavier than others
Even on the Beko?
Great advice – thanks. I will try to find info (although, the fact that it’s leaking steam without the door I may be facing a losing battle).
electrofix wrote: Never force them
Mine wouldn’t even turn to begin to start to get level (i had to use an electric screwdriver to get them to turn – couldn’t do it by hand). They kept on slipping. But, the inside of the machine showed it leaning to the back – a lot.
July 18, 2025 at 8:23 pm #493273electrofix
if you tilt the machine forward to take the weight off the rear legs they move a lot easier
and using an electric screwdriver is a recipe for stripped screws
August 20, 2025 at 11:39 pm #493274bluin
ParticipantUpdate
bluin wrote:Thanks, I’ll stick with same model.
Well, this proved to be a mistake – this one is now dripping water onto the floor after a few washes. This time it’s leaking during the wash cycle rather than leaking steam at the end of the cycle. (It’s square and perfectly level).
I’m beginning to think Currys have a faulty batch – especially looking at recent reviews for this model.
I’m going to ring to morrow and this time try and get a refund and buy a stainless steel Bosch at £699 – 3rd time lucky(?) :/ (But, I suspect I’ll hit a brick wall as it looks like return period starts from your original purchase).
What are BEKO engineers like – anyone with any experience? I won’t trust this machine if it’s not as simple a s faulty seal – which looks fine…
