Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff integ dish no spray.
- This topic has 16 replies, 10 voices, and was last updated 18 years, 2 months ago by
Madmac.
January 17, 2008 at 5:10 pm #33773
Madmac
ParticipantThis chap is around 5yrs old, prob is no water output to bottom spray arm but top one is fine. tried motor cap , no joy. mod is FD8205. Any ideas guys ? Thanks.
January 17, 2008 at 6:17 pm #239992DentedPorsche
ParticipantRe: Neff integ dish no spray.
I’d guess that the alternating valve has stuck. One of the Bosch lads will be able to confirm that I’m right or that I’m just daft. 😛
Or both? 😉
BrianJanuary 17, 2008 at 7:54 pm #239993nomadPaul
ParticipantIt does sound like a waterpoint valve failure . Have you got the full model number Mac ?
January 17, 2008 at 10:12 pm #239994Madmac
Thanks for replies, ENR is S4443NEGB. Had a feeling there must be a valve playin up somewhere. Is it a pig to do ? Its just that ive enough easy stuff to be getting on with, not in mood for hassles in january!
January 17, 2008 at 10:17 pm #239995gegsy
Yea its a pig 😥 Complete heater change.
Lid and sides off, loosen base lie it on its left side and access fom there.
Its a fiddle but when you’ve done a few it gets better.
Check that model number 😉 get if off the stainless of the door inner.Greg
January 17, 2008 at 10:28 pm #239996Madmac
Thanks Greg. Think ill point punter towards local neff agent, like i say, not in mood for it.Good to know the cause though, it was annoying me. Thanks to all. Eddie.
January 17, 2008 at 10:56 pm #239997lerch
As gegsy said it is a heater chamber that needs changing as divertor valve is located inside there and it is a pig of a job.
January 18, 2008 at 1:38 pm #239998dna
not that difficult should take no longer than 40mins to do whole repair.
January 18, 2008 at 2:48 pm #239999Martin
dna wrote:not that difficult should take no longer than 40mins to do whole repair.
40 mins????? 😕
I’d like to see you try? 😉
January 18, 2008 at 7:53 pm #240000gegsy
40mins 😆
Would take that long to get it out and in again then levelling even before repairing, depending on installation 😉Greg
January 18, 2008 at 9:31 pm #240001smartin
quickest ive done one in is 36 mins its easy job when you know how they come apart, ya dont have too lay them on there side, lid off, sides off, 2 rear lower screws,all usual screws inside and salt cap ,(dont take nothing off door or lower plinth ) unclip brake cords from hinge,now look up a couple of inches and you will see steel hinge plates running up, in the middle will be a machine screw holding them there, unscrew it ,if you lever side hinge plates apart just above where screw was while pulling whole cavity towards you (while standing in front of the door) with a bit off wiggling and gentle pulling the whole cavity will hinge towards you , oh and make sure you use the box that new heater came in to put under door to stop it hitting floor, if all goes well you should be looking at the entire contents of the base 😀 like everything in life once you have done it the first time it does get easier. hope this helps everyone smartin
January 18, 2008 at 10:07 pm #240002bobokines
Before going down this line, check that you have diagnosed the fault correctly. Could still be a blocked metering hose!!!!
Bob
January 18, 2008 at 10:47 pm #240003gegsy
If that were the case Bob, you would get insufficient water therefore definately not enough to be pumped to top spray arm. 😀
January 19, 2008 at 12:28 pm #240004bobokines
Whoops, didn’t read the original post properly. I thought it was the top spray not working.Bob
January 19, 2008 at 6:42 pm #240005Madmac
Well if anyone fancies a trip to Dingwall in scottish highlands feel free to ask! Cutest little blonde! (female) and home baked scones..Nice. 😉
