Neff: water left at end of cycle / lights gone out / drying
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Neff: water left at end of cycle / lights gone out / drying
Viewing 5 posts - 16 through 20 (of 20 total)
  • #135266
    Re: Neff: water left at end of cycle / lights gone out / dry
    Dave_Conway wrote:On/off switch or dry joints on the control PCB methinks 😉
    I already took the door off and checked the wires going to the power switch, but I haven’t tested the switch itself. I guess I can check this with my multi-meter. But is the control PCB something I can get to easily? (i.e. without taking the machine out).
    Maybe it’s time to get the engineer out? Does anybody know of a good engineer in the Guildford/Farnham area (GU10)?
    Also I’m not sure what to expect from this machine. I’ve no idea how old it is or how much it cost as it was in the kitchen when we moved in last year. Is it going to be worth attempting a fix?
    #135267
    The on/off door microswitch is a likely suspect then as well as the actual on/off/start switch. The module (located top right of the control panel) however is less likely to be at fault (though cannot be ruled out) as they are pretty robust on this model.
    What is the ‘FD’ number shown on your machine though I wonder?
    Certainly worth fixing though and I’m not sure we have anyone listed in GU land but try this link :-
    Repairs@
    #135268
    Martin wrote:The on/off door microswitch is a likely suspect then
    Would I be right though in thinking that the door microswitch wouldn’t cause the indicator lights to go out? So perhaps I can rule this out.
    Martin wrote:What is the ‘FD’ number shown on your machine though I wonder?
    I’ll check when I get home tonight.
    Martin wrote:Certainly worth fixing though and I’m not sure we have anyone listed in GU land but try this link :-
    Repairs@
    Nobody listed under GU10 I’m afraid.
    #135269
    dleh wrote:Would I be right though in thinking that the door microswitch wouldn’t cause the indicator lights to go out? So perhaps I can rule this out.
    Very true, smart thinking…but the On/off switch would!
    dleh wrote:Nobody listed under GU10 I’m afraid.
    That’s too bad, but try this guy (he should be able to help? :-
    M Lee Appliance Service
    5, Alloway Close, Woking, Surrey GU21 3HY
    Tel: 01483 764851
    #135270
    Martin wrote:That’s too bad, but try this guy (he should be able to help? :-
    Tel: 01483 764851
    Thanks, I’ll give him a try after I’ve checked the on/off switch. No time tonight – but I have just run another cycle – usual problem, only this time the machine is not hot at the point it has cut out (I think it has just done a cold rinse?) So maybe it’s not heat related after all.
    Oh, and the FD number is 7809 (then there’s a gap followed by 440042).
