New Neff w/m motor won’t work?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries New Neff w/m motor won’t work?
Viewing 5 posts - 16 through 20 (of 20 total)
  • #160267
    Re: New Neff w/m motor won’t work?
    anyone here take a guess at why ❓ If a track is blown, how did the old motor still work ❓
    #160268
    eastlmark wrote:anyone here take a guess at why ❓ If a track is blown, how did the old motor still work ❓
    I can send you the .pdf file of the wiring diagram Mark if it will help figure that one? The link that was broken was from the K6 Relay terminal on the diagram as far as I can figure. ..The old motor would tumble in both directions quite happily (the new motor wouldn’t at all) but neither old or new would work on the spin setting. 😕
    I would appreciate the answer as much as you…thanks! 😀
    #160269
    superfix
    😀 Glad to be of help Martin.
    Isn’t it a good feeling when you kill a sticky job. 😀
    #160270
    Intermittent contact acrross burnt relay joint?
    Soldered up two this week already myself – one Indy wm’c. one Zan dw. It’s definitely a weak spot 10A through a small soldered contact.
    One of these days a manufacturer will find a more reliable way – probably already have. What about ISE?
    Mike.
    #160271
    alster
    these motors sometimes wont run properly without the belt on – they will do about 2 revolutions & then stop, this may not be connected to this fault but its worth remembering…………..
