Home › Forums › Public Support Forums › Help And Support › Other Appliances › Old Toshiba aircon unit
- This topic has 30 replies, 3 voices, and was last updated 2 years, 9 months ago by
FloodGoose.
June 11, 2023 at 11:12 am #102019
FloodGoose
ParticipantHi everyone. I have a very old toshiba ras-10skh-e aircon unit that was in place when I moved in. We’re moving soon, but need to get through a hot, humid summer here, whilst packing up the house. The unit stopped working and when I opened it, I found a roast joint of mouse on the circuit board.
I took the board to a local (well, the most local, 90 minute drive each way!) repair place, who replaced the part that was fried. I brought it home and installed it but, probably due to my shoddy installation, the fuse on the PCB blew straight away. Another 3 hour round trip and the fuse and one capacitor were replaced, so this time I was extra careful. I put extra insulation tubing around all the power wires, made sure to check nothing was touching anything it shouldn’t be, and when I turned the circuit breaker back on…nothing.
I disassembled it again, and the fuse was still fine. I took a multimeter and tested every path on the PCB that I could find, including the junctions where the power cables enter and exit, and any wires that connect the mainboard to the small peripheral board etc… and everything shows continuity.
I reconnected it, making sure every connector was firmly in etc, turned it back on, and still nothing.
It’s so old I can’t get any replacement parts for it, so I have to find a way to fix it myself.
So, my question is, if the PCB seems to be fine and didn’t blow it’s fuse, but it did the previous time which shows there is still juice going through the line, where else can I look for the problem?
THe circuit breaker for the unit is functioning gine as far as I can see, snaps nicely back into the on position, and because of how the unit was installed, I can’t see any other point where there’s a fuse of circuit breaker etc…
Thanks so much for any helpJune 11, 2023 at 11:40 am #487214electrofix
Moderatorwould need a look at the board and to know which parts fried to try to come up with a why
the service manual is online to help you
June 11, 2023 at 12:42 pm #487215FloodGoose
ParticipantThanks for the reply. The guy who replaced the initial problem, and then the fuse and capacitor did check the board, and, as I say, I checked every single path on the PCB for continuity.
But, I can take a picture of the board as it is now and post it here if that’s helpful?
Thanks again
June 11, 2023 at 1:00 pm #487216electrofix
Moderatorif all the components are ok then it should work
you need to find a reason why the fuse blew. was it a board fault or an external component that caused it
I can find board overlays but not a board circuit diagram and dont know what components blew or why so its difficult to come up with a theoryyoes post some pics but the is a size constraint so you may have to host elsewhere and post public links
June 11, 2023 at 1:44 pm #487217FloodGoose
ParticipantThanks again Dave,
I’ve uploaded an album here. In the final image, I circled in red the initial part that he replaced, he also replaced, on the second visit, one of the brown cylindrical capacitors(?), the one on the far left of the image with the brown top, and the fuse that blue (which he fashioned from spit and sawdust, lol)
June 11, 2023 at 4:42 pm #487218electrofix
Moderatorwell you need to check on power
diagrams shows power come in the board then it goes out to 2 77 degree thermal fuses
you need to find and check them shows on connector cn04
June 11, 2023 at 5:50 pm #487219FloodGoose
ParticipantTHanks a lot. SO they’re on the board? And they may be damaged even though the multimeter shows continuity? SO maybe they were also samaged at the same time as the othe rfuse (that was replaced?)
June 11, 2023 at 6:38 pm #487220electrofix
Moderatorthis is a switch mode power supply to work they take 240v and rectifiy it to make DC at about 300v on the big cap
but in the circuit are 2 thermal fuses that are on equipment in the unit.and connect ot connector CN04. you need to see if you have a circuit across the CN$ plug, if these fail then there is no power to the power supply
my first job on a dead unit is to see if you have 300v DC on the main cap. if not we need to figure out why
June 11, 2023 at 9:03 pm #487221FloodGoose
ParticipantThanks so much. I’ll have a look in the morning and see if I can figure that out.
I’m really grateful as it’s already humid and muggy, and getting hotter, and the missus is already feeling unwell.
I’ll let you know how I get on (or more likely be back to ask more questions!)
June 11, 2023 at 9:31 pm #487222electrofix
Moderatorbe careful your dealing with high voltage DC
and if the capacitor is charging you can get a shock when its off in certain circumstances
June 12, 2023 at 11:03 am #487223FloodGoose
ParticipantThanks for the warning. Before I go ahead, I wanted to check I’m looking at the right part. The wires from the power input connect to two black oblongs. Are they the fuses? And I should put the multimeter probe into the leads to check the voltage? I’ve attached an album below. Thanks again for the help and advice
https://imgur.com/a/vogVrunJune 12, 2023 at 11:13 am #487224FloodGoose
ParticipantAlso, in terms of precautions, I guess standing on a rubber mat, wearing some rubber gloves, and holding the probes by the insulated part should be ok?
June 12, 2023 at 8:30 pm #487225electrofix
Moderatorfirst what i think i would do is find component L1 on the board
then with all the plugs connected you chould get continuity from the plug, both live and neutral to this component. this is where the power goes to the power supply on the board
this can be done with no risk with a 9v test meter
June 13, 2023 at 5:52 pm #487226FloodGoose
ParticipantThanks again. So, I tested it by putting a probe on each of the 3 cables that lead from the two terminal blocks, and the other probe on the backside of the PCB, and there was continuity on them all the parts RY01 and RY02. But, they seem like switches, so I couldn’t get anything from them to L01, which is a kind of induction coil just next to them, but I don’t know if that’s just because one or both of the switches are open.
So, could you advise me on the next step?
June 13, 2023 at 7:32 pm #487227electrofix
Moderatorlive comes in and goes to term 3 on ry01. it then leaves the board on CY04 term 1 and goes to 2 thermal fuses. it then comes back to the board on cy04 term 3 and goes to L01
neutal comes in and goes to RY02 term 3 it then goes straight to L01
you need to find both circuits from plug to L01 first
