Home › Forums › Manufacturer/WP/Insurer Specific Forums › ISE Trade Support Forum › ISE Forum (Closed) › Quick Wash fault
- This topic has 20 replies, 5 voices, and was last updated 19 years, 9 months ago by
iadom.
July 26, 2006 at 8:45 am #179946
ModeratorRe: Quick Wash fault
But at what cost, 😉 I can have 10 Meg for £34.99 but 4 meg for £24.99 works for me.
July 26, 2006 at 8:48 am #179947gegsy
ParticipantRe: Quick Wash fault
I have BT up to 8meg, usually hovers around 3- 6 for £27.99
July 26, 2006 at 9:04 am #179948iadom
Yes but BT have a 50:1 contention rate, my Ntl connection is 20:1 8)
Thats why yours fluctuates so much.
July 27, 2006 at 4:12 pm #179949iadom
Back on topic, 😉
After a call from ISE HQ I went along to Mrs Phipps today, fortunately I had been supplied with a module before attending.
She showed me one thing that she had noticed before I touched anything.
Switched ON, select 40° Cottons, press Quick Wash, its neon does not light up. Turn selector to 40° Synthetics and you can then select Quick Wash. 😕
Before I even pulled the machine out or disturbed it in any way I removed the mains plug for 1 minute to see if that cleared anything from memory.
I then set to 40° Cottons and this time I could select Quick Wash, however the unplugging seems to be a bit of a red herring because I then fiddled around with various options, filled, emptied, cancelled mid programme etc. Several times I then had the Ready light flashing and could not select anything. The door lock was OK and I made certain that the selector switch was not set ‘ between ‘ programmes. I switched off and left it for 1 minute then found that I could once again use the selector knob. I selected 40° Cottons and Quick Wash, the Quick Wash neon illuminated but I then found that if I turned the selector knob to 60° without pressing the SPC button the light stayed on but went out when I turned it back to 40° and the Ready light started flashing again, if I then turned it back to 60° the Quick Wash neon came back on and the flashing Ready neon went out.I replaced the module with the new one and ran several tests all of which worked fine.
I suspect that there may be an intermittant fault with the selector switch on the module causing this fault.
July 27, 2006 at 10:18 pm #179950kwatt
KeymasterRe: Quick Wash fault
Well that’s a weird one!
No matter though the problem’s solved and I hope the customer is happy and that’s the main thing.
When we get the module back I may have some tests done so we can see if it is a fault of something daft that’s been missed. All well worth knowing about though.
Thanks Jim.
July 27, 2006 at 10:30 pm #179951iadom
I’ll swop you one module for one job sheet, 😉
Customer very happy, I also downloaded and printed out the latest user manual for her. 🙂
