Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Removing torx screws from drum spider – Hotpoint
- This topic has 20 replies, 8 voices, and was last updated 12 years, 9 months ago by
twicknix.
June 19, 2013 at 11:17 am #75908
twicknix
ParticipantI am having a hard time trying to remove the screws but they are all buggered, no matter how I tried, used wd40 – no change, drilled out some but decided not to proceed as I do not want to make the hole bigger for the new screws to go in on the drum.
I can’t remember what I did last time, angle grinder seems to ring a bell but I recalled having difficulties due to the risk of cutting through on the rear of the drum.
I am going to attempt to use this… (I will have to go to the shop to buy this tool – less profit to be made knowing that I don’t do many drum bearings changes – knowing my luck, it probably doomed to fail!)
http://www.machinemart.co.uk/shop/produ … ew+removalhaving lunch right now so hopefully in an hour, I would have thought of a different way…
What other engineers have tried? Would love to know their tried and tested method.
Matt
June 19, 2013 at 11:55 am #396560madangler1
ParticipantRe: Removing torx screws from drum spider – Hotpoint
I normally smack them with a drift a few times before trying to remove them. If they are stuck drill the heads off with either a 8mm or 10mm bit, normally once you get a fair way in the whole head just domes off cleanly.
No damage to innerdrum.
Do at least 3 of these a week this way.
June 19, 2013 at 12:10 pm #396561twicknix
Cheers, the screw heads are so soft and caked in limescale. Drift sounds like a plan but they are simply too soft.
Drill it is then…
June 19, 2013 at 1:06 pm #396562iadom
ModeratorRe: Removing torx screws from drum spider – Hotpoint
Titanium drill, lasts ages and drills them out in no time at all, good idea to use drill cooling fluid at the same time. Don’t waste my time trying to unscrew them, just drill em out and fit new screws every time. The head comes off before the drill hits the drum and as they are virtually all fixed with only one screw per arm you can always use the other slot anyway.
June 19, 2013 at 1:39 pm #396563twicknix
iadom wrote: The head comes off before the drill hits the drum and as they are virtually all fixed with only one screw per arm you can always use the other slot anyway.
Not this particular drum, all six screws are in. It’s WT761. Drilled out 4, 2 more to go. you are right about the drill bit, will buy some decent drill bits.
Thanks Jim
June 19, 2013 at 1:48 pm #396564iadom
Make sure you use the drill on the slower sped setting as well. 😉
June 19, 2013 at 4:59 pm #396565twicknix
Will take note thanks. Too hot to work on the drum, will finish it off tomorrow. Customer wanted it finished for Friday.
June 19, 2013 at 7:11 pm #396566johnnyj
iadom wrote:Titanium drill, lasts ages and drills them out in no time at all, good idea to use drill cooling fluid at the same time. Don’t waste my time trying to unscrew them, just drill em out and fit new screws every time. The head comes off before the drill hits the drum and as they are virtually all fixed with only one screw per arm you can always use the other slot anyway.
I dumped the Titanium years ago and got Cobalt drills last for ages and ages the 8 mm one i have been using has lasted months and i do on average 2 to three a week.
June 19, 2013 at 7:28 pm #396567iadom
DOH, I meant to say cobalt, I have a couple and they show no signs of wear at all.
June 19, 2013 at 8:42 pm #396568Hollytree_Technical
I use the cobalt ones as well – these are the ones that I use – just add some cutting compound and they eat the bolts for breakfast, so far I have not damaged a single drum with them as they take the bolt head off first.
Jem
June 19, 2013 at 9:06 pm #396569Allsorts
That link doesn’t work
June 19, 2013 at 9:08 pm #396570iadom
Works fine for me.
Sent from my iPad using Tapatalk HDJune 19, 2013 at 9:51 pm #396571Allsorts
Maybe it is because I am on mobile.. What is the RS ref number?
June 19, 2013 at 10:03 pm #396572Hollytree_Technical
707-2807
Jem
June 19, 2013 at 10:07 pm #396573Allsorts
