Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › SAMSUNG RS21DCSV1 freezer compartment doesn’t freeze
- This topic has 15 replies, 4 voices, and was last updated 19 years, 10 months ago by
jayzee.
May 29, 2006 at 3:53 pm #18134
jayzee
ParticipantHi, I have a samsung RS21DCSV which the freezer isn’t working properly on.
the fridge seems to maintain temperature correctly, but the freezer is all over the place. it can display the temperature being -14 when you have set it to -25 but inside ice cubes aren’t frozen, then it will display -3 and the ice cubes will be frozen.
When I remove the pannels at the back to reveal the Evaporators (I think they are called) the one in the fridge gets cold where as the one in the freezer doesnt seem to when the fridge freezer is first turned on then over time it will go cold.
both evaporaters at times have frost on them, it seems that the freezer side thinks it is already at the right temperature and therefore doesn’t come on. from what I have read these type of fridges have a defrost function, maybe it is stuck in this cycle in the freezer? is this possible.
whats going on?
thanks for any help/suggestions
J
May 29, 2006 at 4:03 pm #177839kwatt
KeymasterSounds like a board or thermistor failure, but I’m sure one of the guys that have done a lot of work on these will offer more insight. I wouldn’t recommend a DIY fix though as Samsung aren’t the easiest to work on. 😉
May 30, 2006 at 12:34 pm #177840jayzee
ParticipantRe: SAMSUNG RS21DCSV1 freezer compartment doesn’t freeze
thanks for the info,
would like to try and check the simple things myself if possible to start with.
If I can check the obvious/simple things first and swap any small parts that could be causing the problem and then if thats no good I will have to revert to calling an engineer.thanks
J
May 30, 2006 at 3:30 pm #177841admin
KeymasterRe: SAMSUNG RS21DCSV1 freezer compartment doesn’t freeze
HI
press and hold the top 2 buttons until the display flashes and it will give you a dash or 2 in a figure 8.
let me know which dash comes up.
bryan
May 30, 2006 at 6:34 pm #177842jayzee
i have held down the power freeze and power cool buttons for about 6 seconds the display flashes and it beeps then the the screen goes completely blank for about 30 seconds before it beeps again and the screen goes back to normal.I don’t see any dashes in the digital display
is this bad 😥
thanks for the help
J
May 31, 2006 at 8:51 am #177843jayzee
when I did the above the freezer seems to cool down and reaches the temperature set on the display.
I set it at -24 and the display reads the freezer temperature is at -24. inside the freezer teh ice cube tray I put in is frozen and the freezer seem nice and cold.then about 5 or 6 hours later the temperature reads the same but the ice cubes have defrosted again.
woudl I be right in thinking its the defrost functions that sat fault, possibly not turning off?
thanks again
JMay 31, 2006 at 10:40 am #177844admin
that points to there is no failure on memery for the thermal fuse,heater,fan so i suspect that it may be a system fault which is a engineer visit.
bryan
May 31, 2006 at 12:06 pm #177845jayzee
so you were expecting to see some dashes that signify what has failed.
therefore you are suggesting that there is no problem with a thermal fuse, heater or fan, suggesting that the defrost cycle is not at fault.
when you say system fault, what could this cover?
I work with computers, electricals and mechanics regularly and if I told you there was a system fault it could indicate any one of a number of things wrong when refering to a computer. to me a fridge has to be way simpler but could the problems be as varied?thanks again for the help
Matt
May 31, 2006 at 1:43 pm #177846admin
The system that I am refering to is the refrigeration system that is a sealed system and not electrical.
bryan
May 31, 2006 at 2:18 pm #177847jayzee
Looks like I need an engineer to come and have a look 🙁 . anybody able to suggest one near stockport/manchester postcode SK4 I have tried the repairs@ function but no luck.
From what I have read alot of engineers don’t know that much about these fridges and I don’t want to pay for someone to come out who is only going to guess like I am, what the problem is and charge me for the privilige. Should i be worried about this?
if it isn’t anything electrical what things could be possibly wrong. faulty compressor, gas leak….?
when you say there is no failure on memory, are you saying if one of the electrical items had a problem it is stored in memory until you push the top 2 buttons and then it diplays the dashes as a code to the fault. does this totaly rule out the electrical system from being the problem?just that from the samsung posts I have read on this site my problem seems similar to those who have had a fault with the defrost function.
are there other engineer codes to test other parts of the fridge as I would assume that the refridgeratation system itself should be able to be tested for correct functioning?
J
May 31, 2006 at 2:44 pm #177848admin
once you turn off the appliance the fault codes are cleared,if you have turned off the appliance then it will not show the previous faults,it would need to be left on for a few days till the fault re occures.
bryan
May 31, 2006 at 3:42 pm #177849jayzee
does pushing the power freezer and power cool buttons cause any sort of system reset. just that before I did this the freezers temperature was all over the place then after pushing the buttons it straight away cools down to the correct temperature and works fine for 5 or 6 hours
June 16, 2006 at 9:09 am #177850jayzee
with help and tips from the great members on this forum I have managed to test the main components that fail on this type of freezer and have not found a problem.I have tested the heaters looking for open circuits on the fridge and freezer compartments but bote give a reading to indicate they are closed and therfore ok.
I have tested the sensors in both compartments that are behind the blue plastic covers and these both seem to be fine and give a reading that varies with the temperature of the sensor.
I have tested the defrost sensor in both compartments and get a reading that varies with the temperature of the sensor, again I assume this is ok.
i have tested the o/load circuit and get a closed circuit on both sides of the fridge.
the fridge keeps cool although the freezers temperature is all over the place and rarely gets down to what it should be and I have been informed that if the refrigeration system was the problem I would be experiancing very little cooling or nothing at all so I am assuming thats not at fault
so with my limited knowledge all I can deduct is the control board is the problem.
Would this be a good guess?
is there anyway to check for sure without getting a new one?
If it is this and i neeed a new one, where do I get one?thanks
Jay
June 16, 2006 at 9:22 am #177851admin
hi
this sounds like a system fault which will require a engineer visit.
bryan
June 16, 2006 at 10:25 am #177852jayzee
thanks for the reply and I appreciate your thinking that at a certain point if the problem isn’t obvious its easiest to just call an engineer.you have suggested that the problem is probably a system fault but I have conflictioning advice suggesting that if there was a system fault very little would be happening in either compartment.
the fridge side seems fine and keeps its temperature, i realise that the freezer is having to cool down a lot further but still, from what other people have said if the problem was the compressor or gas it just wouldn’t be working properly at all.
the other thing is that the read out on the front doesn’t really seem to match the temperature inside the fridge, surely if the system was at fault the front display would just show that the real temperature inside?
to be convinced that this is a system fault I just need to have an idea of the process of what is going wrong and how its creating the temperature values I am seeing on the front display and what it is doing on the inside which is making it fail to get down to the temperature and not really give a correct reading of the temperature inside.
Jay
