SAMSUNG RS21DCSV1/XEU recurring fault or not fixed?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum SAMSUNG RS21DCSV1/XEU recurring fault or not fixed?
Viewing 7 posts - 16 through 22 (of 22 total)
  • #158979
    Dal5band
    Re: SAMSUNG RS21DCSV1/XEU recurring fault or not fixed?
    The icing up problem is back within a week – changing the back panel in the fridge didn’t fix it. Will be calling Comet again.
    #158980
    Dal5band
    Mrs Dals5 here
    Several “repairs” LATER!!!!!!!!!!!!!! I had a moan at Comet whose
    the engineer turned up again a with a look of dread 🙁 on his face and we are getting a replacement fridgefreezer from them. Only taken since October!!. 😀
    #158981
    fridgeman999
    Hi being an ex eac eng, its only a week since i have played with a rs21, first thing the ins book warns you about running it too cold, yes bit s need to be changed, but you can fix it, trust me.
    #158982
    Dal5band
    During the various visits, I noticed that the engineers tested the defrost sensors and the heater and said it was OK. They seem to just do a continuity test with a meter. If they are thermocouple type then I would think they deteriarate gradually so a meter test will not show a problem until the unit fails completely ? How do these sensors work ?
    #158983
    jed
    Problem can be due to evap sensor out calibration,evap heater/themal fuse o/c.Sometimes the plenhiem becomes porous absorbing water and causing ice build uparound the fan.
    #158984
    robbo1973
    hi all i have worked on tonnes of these and the problem is only cured by replacing the fridge evap cover. the insulation soaks up water and then starts icing up jamming fan etc samsung also recomend changing defrost term sensor (yellow wires) at the same time but there is definetley a modified back panel available hope this helps. 😆
    #158985
    bugalug
    Hi, can anyone tell me how long this problem has been known. We have just started having the problems everyone is talking about (ie., noisy fan, display flashing, no water etc – what will happen next?) Our machine is now just out of warranty! 🙁
