Samsung rs53k4400sa dead
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung rs53k4400sa dead
Viewing 10 posts - 16 through 25 (of 25 total)
  • #471074
    thats the one
    look at the markings on it and see if there is a number
    are those marking on the chip itself or on the board ?
    Mrplumber
    Ah right. The numbers I stated were marked on the board.
    on the transistor it has
    k mbrf20
    u 150cta
    some symbol then 525
    #471077
    ok was worth a try
    maybe faulty but you would have to know how to check a diode to find out
    thought it may have been a power regulator but its a Shottky diode pair in a case used for rectifying the ac output of the switch mode power supply. they can go short circuit and cause these sort of faults
    Mrplumber
    Ah your correct. I looked up transistor and thought it was it as looked similar. But googled it and your correct. It has the diode sign.
    multimeter does have diode setting but would this be irrelevant now.
    the transistor thing sounded right as maybe it wasn’t putting the correct voltage out.
    could a diode still be suspect?
    #471079
    yes they go short circuit
    had one last week on a tumble dryer
    Mrplumber
    Sweet mate thanks. Once I fit the new pcb I will learn and fix the old one and show what it was. Your help is appreciated.
    #471081
    Mrplumber
    Pcb arrived. It’s all up and running.
    further learning of the old pcb I found a faulty diode was the cause. On the board it’s marked ds2 and sits next to the heat sink.
    just in case it helps anyone
    #471082
    Gadjet87
    Same thing happened to me. Can someone guide me on how to test whether the diode is working or not? Thank you
    #471083
    a diode is a one way device
    will be lots of videos on utube how to test
    but
    set multimeter on diode setting
    put meter leads on diode look ant the reading then reverse leads and they should differ greatly
    if you get the same reading both ways it could be faulty. to be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure unsolder from board and test again
