Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung RSH1 Side-by-Side Compressor not running
- This topic has 21 replies, 6 voices, and was last updated 12 years, 2 months ago by
matt.s.
January 25, 2014 at 11:31 am #408109
lee8
ParticipantRe: Samsung RSH1 Side-by-Side Compressor not running
Yes it should be for yours.
January 25, 2014 at 11:45 am #408110matt.s
Thanks! Where can I get a new one? I couldn’t find it in the uk whitegoods store. Searching the internet, I come up with a lot of similar inverter PCBs, but none has the same product code used in my application. The marking on my inverter PCB says “DA41-00288A Ver. 1.5”
January 25, 2014 at 1:33 pm #408111matt.s
I probed the inverter output using an oscilloscope. What you see in the attachment is the voltage at the U and V pins of the inverter PCB, measured at the connnector towards the compressor. U W and V W look the same. I put the application in forced operation (FF1).
Shouldn’t the signals be phase shifted? It looks to me like something shorted out and and some kind of line voltage is applied to the compressor, because the signals I’m gettig are 50 Hz, 320V Peak-to-Peak and in phase. But it’s hard to tell what exactly without a schematic, any ideas?
January 28, 2014 at 6:15 pm #408112matt.s
I just installed a new inverter PCB, but I’m still getting the same error signaled by the LED: “SPM Fault”. I’m running out of ideas, is there anything else I could try?
I checked the signal “comp” on the connector from the main PCB to the inverter PCB, it’s 5V, 50:50 duty cycle, 400Hz. From what I read, that’s what it’s supposed to be.
June 3, 2014 at 8:40 pm #408113r4obo
Matt.s please give me a solution for your problem. I have the same and I just changed sub-inveter PCB with any success. If You solve your problem please give me any information. I’m just crazy!
December 30, 2014 at 1:46 pm #408114minimarvel
Bit late but might help another if finding this thread.
Everything pointed to the Inverter board as measured 320 – 88 volts DC on 2 outputs and 187 – 67 on the third…consistently(without motor connected). Bought new board and compressor just to be sure…..
New Inverter didn’t fix it. New compressor did.
My comment…. Samsung warranty not worth the paper they are printed on. 10 year compressor, yes, but by the time you pay someone to fit a new compressor, and still end up with a 6 year old fridge you have been better to buy a new one instead of waiting for the other “timed” components to fail. But then if manufacturers built good to last 20 years, they would all go out of business.
Samsung warranty covers parts only, irrespective of how shiny the warranty stickers are.
February 11, 2015 at 8:59 pm #408115matt.s
Sorry for the late response, just found this thread again. In the end I gave up and sold the fridge as malfunctioning, someone picked it up for the spare parts. Pretty sure the fault was the compressor though…
