Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Senor meile dyer
- This topic has 18 replies, 4 voices, and was last updated 7 years, 10 months ago by
kaibart.
May 21, 2018 at 7:08 pm #93947
kaibart
Moderatorresources/image/4742/rokbox.jpg Hi guys anyone know what will cause this Miele dryer to stop after a minute I’m stumped as I don’t work on these much, or if anyone has any tech info that will be great tia kai 🙂
May 22, 2018 at 5:13 pm #455977neon_3SP_glow
ParticipantRe: Senor meile dyer
https://usermanual.wiki/Miele/t-294-c.3600732569
That’s the user manual, it might help.
May 22, 2018 at 9:28 pm #455978kaibart
ModeratorRe: Senor meile dyer
May 26, 2018 at 9:59 am #455979kaibart
So been back to this dryer this morning and the sensor on the element ntc and thermostat are all ok 90kohms on ntc and 0.50hms on thermostat front sensor in front duct also reads ok is this a possible relay board for the heater?
May 26, 2018 at 12:59 pm #455980neon_3SP_glow
Having same issue.
Ele box sensor room temperature is 138kohms.
Under door sensor is reading 13kohms.
No neutral being switched from relay board…
May 26, 2018 at 1:01 pm #455981neon_3SP_glow
Looks like element relays are switched in series with neutral relay as they all have a thin live going to back relay legs. This makes me think the neutral relay isn’t switching.
May 26, 2018 at 5:40 pm #455982neon_3SP_glow
Was planning to desolder and swap the relays – the element relays did allow voltage through. But the circuit was never completed as the neutral relay didn’t switch – alas, trying to hold the board whilst applying the iron AND trying to prize the relay away was impossible.
It’s so awkward when the relays have 4 legs right close to each other. By the time you get the solder melted and start pricing the relay away, the other legs have cooled down and nothing budges.
Infuriating tbh.
I’m trying to find what the sensors (kohms) should be rated, but finding nothing.
Sigh!
May 26, 2018 at 8:09 pm #455983electrofix
You need desolder braid to take most of the solder off first
May 26, 2018 at 9:11 pm #455984neon_3SP_glow
electrofix wrote:You need desolder braid to take most of the solder off first
Now I do feel silly!
Thanks for the hedas up Dave.
May 31, 2018 at 1:19 pm #455985neon_3SP_glow
Have a look here my friend:
Derived from this manual:
May 31, 2018 at 7:30 pm #455986kaibart
Unfortunately I had to ber the appliance as the customer wouldn’t pay over £80.00 for repair the brushes on top where shot. I think he is going to buy a cheap dryer 🙁 did advise but no telling some customers
June 30, 2018 at 2:31 pm #455987kaibart
So I’ve picked this dryer up off customer and I’ve got correct readings on front door ntc rear ntc and thermostat on heater and check all wiring to heater relay pcb I’ve another meile dryer with a relay pcb but it only has 3 relays on it and is still the same any ideas?
June 30, 2018 at 4:12 pm #455988electrofix
to be certain the relay board is your fault or not you need to measure the relay coil voltage. you can look on the relay but I am expecting 12 volts or so.
get a piece of kitchen roll, wet it and squeeze it out so its still wet but wont drip. place this across the brush gear at the top of the machine to simulate wet clothes. then run the machine and measure the relay coils to see if they energise. If you get the voltage then its the relays if not its something elseDave
July 2, 2018 at 5:02 am #455989Kentish
Easy to see if the brushes are worn, by the tell tale “click”each time the sensor bands joint hits the underside of the brush assembly.
Best checking heating issues on timed drying, not sensor drying.July 3, 2018 at 8:02 pm #455990kaibart
That’s what I’ve been running it on I think it a air flow issue when I took out the condenser and 2 door filters it didn’t stop it ran through the 30 mins timed dry
