Servis Pump question
Viewing 15 posts - 1 through 15 (of 24 total)
  • #25215
    LeeJones
    I bought and fitted a new pump for my servis M6011 now the only problem is that i cant attach the pump the washing machine frame as the old one did
    My question is simply if i dont fix it to the frame would it be damaged or can i leave it sitting just above the frame
    Thanks,
    #204922
    Dave_Conway
    Re: Servis Pump question
    In what way won’t it fit to the chassis ?
    Normally these pumps have no thread in the base and the existing bolts cut their own on the way in 😉
    #204923
    LeeJones
    It doesnt reach the holes the only way would be to bend the pipe thats coming from the drum ive pushed the pipe off the drum far as it will go on the pump but i cant screw it down because the pump is more to the back of the machine than the holes are 😕
    Its just the postion of the pump is well looks impossble to fit it where the old one was
    #204924
    Dave_Conway
    LeeJones wrote:It doesnt reach the holes the only way would be to bend the pipe thats coming from the drum
    Eh ? 😕
    The hose that fits to the pump comes from the filter unit at the front, not from the drum (assuming the model number is correct) 😉
    #204925
    Washman
    You have the wrong pump there are 2 pumps which look similar one has the motor coil facing the outside of machine and the other has coil facing in wards towards drum . Whats the serial number of machine thats the only way to make sure of correct pump.
    Mike
    #204926
    Kirk
    Hi Dave doesn’t this model use the short pump which is at the wrong angle and you could take pump motor off and put on old housing but I think wires or the connections need to be modified.
    Kirk
    #204927
    LeeJones
    Dave_Conway wrote:
    Eh ? 😕
    The holes on the frame it seems to be needed to force the pump on the frame which then makes the pipe get a minor bend
    My model number is M6011
    That is the one i ordered http://www.ukwhitegoods.co.uk/modules.p … cts_id=162
    Serial number is 20050710203-010077205-01
    Pump works but it makes a noise because of the vibration on the frame of the washing machine
    Kirk wrote:Hi Dave doesn’t this model use the short pump which is at the wrong angle and you could take pump motor off and put on old housing but I think wires or the connections need to be modified.
    Kirk
    Could that be done since its the motor on the old one thats making a noise and attach the motor to old part
    #204928
    LeeJones
    Ok ive but the new motor on the old pipe part my question is ive got 2 cables both grey and ones L and the other is N and there is no marking on the cables which one would go where and question is what would happen if the wrong cable went on the wrong plug on the pump motor 👿
    Last time i attempt to fix a washing machine 😳
    #204929
    It’s an AC circuit, so for this application it won’t matter which way round you wire the pump motor.
    LeeJones
    Penguin45 wrote:It’s an AC circuit, so for this application it won’t matter which way round you wire the pump motor.
    Ok thanks penguin i just wanted to be safe than sorry 😳
    #204931
    Kirk
    No it is not a problem but the wires don’t reach properly on some of the models or the plug connector is wrong! so you sometimes need to modify, which is not a problem for an engineer but for a customer might be. Where the correct pump doesn’t cause a problem.
    Kirk
    #204932
    Dave_Conway
    LeeJones wrote:Serial number is 20050710203
    Yep, that serial number uses the short bodied housing, I assume it’s sorted now though by swapping them over ?
    #204933
    LeeJones
    Yea its fine just need to but it back together 😆 well try anyway the cables do reach just pull them back
    #204934
    LeeJones
    Ok now this new pump is making one hell of a noise like a deep sounding growl type noise it pumps water out but its making more of a noise than the old one how come ?
    It sounds fine when pumping water out but when it runs dry it sounds pretty bad even the old one which has worn out doesnt sound that bad 😯
    #204935
    Dave_Conway
    Is it secured tightly to the base and not touching the side panel etc ?
    It may be a dodgy pump, if it is, please reply to the shop@ email notification and I’ll sort it.
