Sharp kd-hhh9s7gw2-en
  • #98967
    0adbylad1
    Hi brought the above as a bit of a project
    Ive nothing on the display but every 4/5 minutes i get 3 beeps??
    Anybody got a fix or ideas??
    #474523
    don
    Just to give the guys a heads up this is a 9kg heat pump condenser dryer 😉
    Don
    #474524
    0adbylad1
    Yes sir it is
    Ive tried to upload an image of the pcb lol but im new to the forum and cant seem to keep it within the limits
    #474525
    0adbylad1
    As that worked ??
    #474526
    washingmachinewoman
    Afraid not. You need to share your file and post the link to that file.
    #474527
    0adbylad1
    washingmachinewoman wrote:Afraid not. You need to share your file and post the link to that file.
    OK so ill try this
    ​​​​​​https://drive.google.com/file/d/1sfv…ew?usp=sharing
    So that looks like its ok 9i hope)
    The reason ive posted this image …i think this machine as i said i brought knowing it had some problems and i think some of the connections to the pbc might be in the wrong place
    If you look closely at the drum you will see a connector with no wire…this cant be right as i think its a sensor
    Im just hoping theres a tech out there thats had experience with this machine or someone as one and could maybe take a photo of just how it should be
    I know we live in dreams 😎
    #474528
    no it still needs a password
    have added 2 of them above
    If you get an E03 error and, I presume that’s what it is as there’s no mention of an audible alarm, then it’s a water tank fault. What about it, no ideas given just that it has a problem al it says is, “Aqauswitch connector is disconnected” and that’s all there is.
    0adbylad1
    kwatt wrote:If you get an E03 error and, I presume that’s what it is as there’s no mention of an audible alarm, then it’s a water tank fault. What about it, no ideas given just that it has a problem al it says is, “Aqauswitch connector is disconnected” and that’s all there is.
    The error code is E00
    I have now moved one of the wires as it appeared wrong to me, i now have no display and if the machine is left on every 3/4 minutes i get 3beeps
    #474531
    E00 is a comms error between the main board and interface at the front.
    0adbylad1
    kwatt wrote:E00 is a comms error between the main board and interface at the front.
    AH! but what would the fix be?
    #474533
    Finding out why there’s a comms error and fixing it as, they do not explain the reason why, only what it is.
    0adbylad1
    Just an update guys
    Ive still got this very expensive shelve lol
    Just wondered if there were any wiring diagrams out there
    #474535
    as far as i know sharp tech info is very hard to get
    if its a comms error might just be a bad connection on the link between the boards. try taking the connectors off and replace them to clean contacts
    I may be able to find one, don’t know but I’d need to do that during the day.
