Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Siemans XLM 1200 washing machine.
- This topic has 18 replies, 4 voices, and was last updated 14 years ago by
Pandora99.
March 13, 2012 at 2:53 pm #370796
ParticipantRe: Siemans XLM 1200 washing machine.
Pandora99 wrote:Tell me about it, I forgot I had stuff in it the other week…..two hours later…… :rolls:
There you go then, now we’ve cleared that up you now have a clear picture of what’s wrong and I’ll leave it in your capable…… 🙂
March 13, 2012 at 3:02 pm #370797Pandora99
Martin wrote:
Pandora99 wrote:
Tell me about it, I forgot I had stuff in it the other week…..two hours later…… :rolls:There you go then, now we’ve cleared that up you now have a clear picture of what’s wrong and I’ll leave it in your capable…… 🙂
Thank you. 😀
Now to decide whether to get a Siemens engineer £89 + cost of part or a perhaps a local one (not the one who said it was the control board) Although when he took the top of the machine off he did point with his screwdriver to a black plastic part with wires coming from it and said ‘there’s your problem’ He also tested it with a meter????
March 13, 2012 at 3:17 pm #370798Martin
Pandora99 wrote:Although when he took the top of the machine off he did point with his screwdriver to a black plastic part with wires coming from it and said ‘there’s your problem’ He also tested it with a meter????
Sorry, but I don’t hold with that diagnosis nor can you simply “test it with a meter”…. It’s not possible short of removing the complete control panel, unhooking the module from the panel, disconnecting several securing cable ties and finally removing the circuit boards own protective covers to peer inside at the printed circuit board and its surface components.
Pandora99 wrote:A local engineer came out and tested something in the cavity of the machine and he said it was OK
To access and test the heater the complete front panel including door has to be removed. You cannot test it from the top or from the back. You cannot even get at it from underneath unless you remove a heavy metal baseplate, which I doubt was ever attempted TBH…..all a bit suspect. :rolls:
March 13, 2012 at 3:30 pm #370799Pandora99
Martin wrote:
Pandora99 wrote:
Although when he took the top of the machine off he did point with his screwdriver to a black plastic part with wires coming from it and said ‘there’s your problem’ He also tested it with a meter????Sorry, but I don’t hold with that diagnosis nor can you simply “test it with a meter”…. It’s not possible short of removing the complete control panel, unhooking the module from the panel, disconnecting several securing cable ties and finally removing the circuit boards own protective covers to peer inside at the printed circuit board and its surface components.
I think I will ask a Siemens engineer to carry out the work this time. 😕
