Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › siemens dishwasher programmer problems?
- This topic has 28 replies, 5 voices, and was last updated 19 years, 2 months ago by
abingdonboy.
February 19, 2007 at 4:45 pm #201402
gegsy
ParticipantRe: siemens dishwasher programmer problems?
It shouldn’t really back feed as it has a non return flap 😕
What the best practice is, is to make sure that when the waste pipe leaves the spigot, it needs to go up into a loop higher than the the spigot so that back fill cannot take place.HTH
February 20, 2007 at 8:58 am #201403abingdonboy
Hi Greg,
Thanks again for the further help….
After i wrote the mail i started to think about it and came to the same conclusion, have reinstalled the U bend (removed during original fix) and all is now fine.
Where is the non return flap? I might give it a clean….
Thanks again.
AB.
February 20, 2007 at 9:02 am #201404gegsy
abingdonboy wrote:Where is the non return flap? I might give it a clean….
Its internal on the drain pump housing, never been a problem 😉
February 20, 2007 at 9:03 am #201405Martin
Under the pump impellor cover (black rubber flap valve sits in recess)
April 3, 2007 at 10:50 am #201406abingdonboy
Hi All,
The machine has been working fine for a few months, but has now developed a new fault…The top spray arm isn’t moving, and the pressure seems reduced to the lower spray arm.
Where should i be looking?
Once again, any help much appreciated.
AbingdonBoy.
April 3, 2007 at 10:56 am #201407Martin
abingdonboy wrote:Where should i be looking?
The water point cam has packed up on the Heater Unit (Instanteneous Water Heater Bosch call it). If you remove the top spray arm unit (by the drain filter) and shine a torch down the 2 inlet tubes you will see the cam. Sadly they cannot be accessed or repaired though. Major strip down to replace heater unit the only cure. 🙁
Click on link below for expert help sorting it! 🙂
April 3, 2007 at 11:26 am #201408abingdonboy
Hi Martin,
But i have only just replaced this part!!! (read previous posts)
Do the arms work independently of one another? If so then this may not be the problem…
AB.
April 3, 2007 at 11:31 am #201409abingdonboy
On further inspection the top arm is in fact working, but when the door is opened the water pressure doesn’t seem as high as it use to be…
April 3, 2007 at 6:44 pm #201410abingdonboy
apologies for the previous posts, i hadn’t run a full cycle at that point.
I have now tried to run a full cycle…
The fault code ‘1’ appears (as it did with the last problem, but this time the heater isn’t open circuit, and is getting 240v when required) but this time i believe it is due to water level during the cycle. The machine fills as it should, filling the clear plastic reservoir to the left of the machine, and starts washing, but when i returned to the machine during the washing most of the water had gone, and when left for the cycle to end, it never ends, but the machine is empty and it sounds like it is still trying to pump out…
What can this be?
I can’t afford to spend more money on parts for an unreliable machine, so please say it’s something cheep to fix…
AB.
April 3, 2007 at 6:56 pm #201411gegsy
Sounds like it starts to work but then develops a leak thus dropping water level so much that the microswitch on heater is not actuated anymore, thus giving error 1. The base now probably has water in it from the leak and has activated the anti flood float (front left).
Un plug appliance before investigating :plug:Greg
April 3, 2007 at 7:15 pm #201412abingdonboy
Hi Greg, i thought of that, but no leak present…
Anything else?
April 3, 2007 at 7:18 pm #201413gegsy
….and you have checked that ribbed hose at the front is clear from gunge ??
April 3, 2007 at 7:26 pm #201414nomadPaul
the chances are that the pressure chamber is clogged up , causing probs with fill levels – This assembly sits at bottom right edge of the main ‘water reservoir’ on the LHS – it has two microswitches on it , with the top one being used for ‘overfill’ probs. This may be operating if the water coming in is ‘backing up’ and switching on the pump , thus draining water . Not enough water during the rinse cycle will mean no heating so appliance will just keep running with little water in it , waiting to heat up. Clear this pressure chamber and the ribbed hose and you should be sorted
April 9, 2007 at 7:47 pm #201415abingdonboy
Thanks again to you all, a simple case of cleaning out the chamber (as described by nomadPaul above) and all now appears to be working well again…
Would the dishwasher cleaners available in supermarkets work at cleaning this in future? Or does it require a periodic strip down and clean?
Seems like a weak design for it to clog in a four year old machine…
AB.
