SIEMENS DISHWASHER SE64630GB/12
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries SIEMENS DISHWASHER SE64630GB/12
Viewing 15 posts - 1 through 15 (of 17 total)
  • #27288
    funkyboogy
    replaced door seal lower,
    emptied water from base…
    whilst testing app, it just went dead..only thing it will do is pump out if you activate anti-flood
    getting 240 to and from on/of switch.. and getting power over to pcb,
    no dryjoint @ pcb..
    no lights at top, checked for loose wire etc…
    had previosly tested appliance to find out where leek was coming from, and it worked fine.
    any ideas….cheers ally
    #213390
    Re: SIEMANS DISHWASHER SE64630G/12
    Check the 2 microswitches on the pressure switch unit? 😉
    #213391
    funkyboogy
    hi martin,
    where are the 2 micros situated,
    ive checked the 2 that are situated beside the water infill tank, 1 of them brings on the anti flood,..
    im not getting 240 to overfill valve, the one thats in the cupboard, seems to be only supplying a live to it.
    no lights on control panel at all. wires inside door are ok.
    cheers ally
    #213392
    gegsy
    Earth leakage can sometimes cause weird faults 🙂
    funkyboogy
    Re: SIEMENS DISHWASHER SE64630GB/12
    would it stop lights from coming on…
    ally
    #213394
    gegsy
    Possibly 😕 Doesn’t take long to eliminate, saves a wild goose chase 😀
    funkyboogy
    cheers gegsy,
    would you remove earth @ plug. to check ?
    if not whats the best thing to do,
    and if not an earth leak, whats next
    ally
    #213396
    funkyboogy wrote:replaced door seal lower,
    Ah! Now having read your first post (again) I have just figured what the problem is…………………because the base had previously flooded, likely as not the water block came into effect and shut off the supply to the valve. 😉
    Simply take the air hose off the valve end and blow thru’ to clear it….BINGO…sorted I reckon? 😀
    Did the door seal leak cause the base to flood in the first place I wonder? 😕
    #213397
    gegsy
    Ere Martin
    Can’t see an airline on this model 😕 and would it turn all the lights off if flood activated?
    FB, you could check module for charred connections also.
    funkyboogy
    cheers guys,
    1st i have taken fill hose of at both end , ie undersink and at water tank,
    ,when tested @ supply to lock out valve i was only getting a live to it,
    2nd…leak was caused by loose salt container nut/washer..
    but after i repaired it i also noticed a drip coming from door seal,
    3rd , gegsy the module looks in perfect cond, i have looked over everything twice in this d/w..
    i have checked it up to the on/of switch.240 up to and through switch, but dont know where its goes from there. pump will run if you lift up anti flood device.. it seems like it isnt sending 240 to board or if it is the board isnt responding…
    ally…..confused
    #213399
    clivejameson
    There is always the possibility that the pcb just happened to fail while you were there?….just a thought
    #213400
    funkyboogy
    anyone got a wiring dia for this app
    ally
    #213401
    funkyboogy
    cheers for email gegsy.
    do you know what starter ptc is and where its situated on appliance ??
    ally
    #213402
    gegsy
    FB, it will be on re circ motor AFAIK.
    funkyboogy
    something like a start cap,?
    im beginning to think pcb faulty,dont realy want to buy one and find out its not
    any idea where to check if getting 240 to pcb?.
    ally
