Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Single gas hob: safe to use?
- This topic has 23 replies, 5 voices, and was last updated 11 years, 5 months ago by
kr236rk.
October 31, 2014 at 1:48 am #82836
kr236rk
ParticipantHi,
An elderly relative of mine has this single hob. It has no tap on it, it’s live as soon as you plug it into the gas point (mains). Is it safe to use or, can it be made safer (adapter), or is there anything like this available that has an on/off tap built into it please?
Thanks,
KR
October 31, 2014 at 7:15 am #420945Martin
ParticipantRe: Single gas hob: safe to use?
Wow that looks a scary thing and far from safe to use. Is this device in the UK?
It’s like some weird contraption you would see in Latvia or Bosnia maybe? 🙁
October 31, 2014 at 4:54 pm #420946SAMURI
DO NOT USE IT as there would be no safety cutout to cut off to the supply if the flame was extinguished
Otherwise as Basil Brush says Boom Boom.
Bob
October 31, 2014 at 5:57 pm #420947kr236rk
Thanks, that what I thought when I saw it. Apparently it was here when the current owners moved in – this part of the UK has power cuts every now and then.
Is there a safe version of this single hob please – even if it has to be fitted by a certified gas engineer?
October 31, 2014 at 7:20 pm #420948Martin
I think a single or double electric hotplate a safer solution. An example of which is shown HERE.
October 31, 2014 at 8:28 pm #420949kr236rk
Yes, thanks but:-
kr236rk wrote:this part of the UK has power cuts every now and then.
We need a gas back-up for when the lights – & everything else – goes out 😮
October 31, 2014 at 9:34 pm #420950Martin
In that case……
October 31, 2014 at 10:26 pm #420951kr236rk
Thanks. Is that mains or gaz please? We just want a hob for the gas supply – like a gas cooker in miniature 😉
October 31, 2014 at 11:00 pm #420952kwatt
KeymasterRe: Single gas hob: safe to use?
Why to just visit a camping store and get get a stove there that runs off a small propane container?
October 31, 2014 at 11:18 pm #420953lee8
Camping burners should not be used within a domestic dwelling, your home.
October 31, 2014 at 11:26 pm #420954kr236rk
Yep, are there any certified gas engineers on this forum please?
I need some more advice here.
Thanks again.
November 1, 2014 at 8:24 am #420955Martin
kr236rk wrote:We just want a hob for the gas supply – like a gas cooker in miniature 😉
You either have one or the other which is it to be? A single fixed gas hob requires electric for ignition as does a small single oven. That crude dangerous gas ring is something that would normally be in a laboratory or lecture theatre and certainly unsuitable for an elderly relative in a domestic environment.
If the portable CampingGaz unit is not suitable then the only safe alternative is to have a fully fitted single (or dual) gas hob installed. That would involve re routing the gas supply pipe and cutting and fitting the hob in the work surface.
A “miniature gas cooker” is not something available for installation in a house but rather in a caravan using a butane gas cylinder.
November 1, 2014 at 4:31 pm #420956lee8
I’m gas certified. What u want to know?
November 3, 2014 at 2:47 am #420957kr236rk
Thanks to all & forgive my ignorance. On encountering the single hob – which looks like memorabilia from a desert Monty campaign – I thought there might be something more modern and safer on the market. But there obviously isn’t. We’ve decided to swap a multiple electric hob for a (certified & fitted) gas one – it will fit in the same space.
November 3, 2014 at 4:56 pm #420958lee8
I’m afraid regulations don’t allow gas appliances to be picked up a moved around like a flame thrower, whilst most people would not, children and idiots need to be protected by the regs. You see the contents of the top section of a gas meter contains just the right amount of gas to flatten 2 of the average sized three bedroom homes. So you wouldn’t want to burn through the pipe that feeds that hob unless your an idiot, you may find it funny but l doubt your neighbours would.
