Slight Odour Left on Glasses (Bosch Dishwasher)
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Slight Odour Left on Glasses (Bosch Dishwasher)
Viewing 15 posts - 1 through 15 (of 18 total)
  • #12895
    Shaunf
    I’ve got a Bosch dishwasher (SGS6302GB/07) and I’ve noticed for a while that a very slight odour is left on the glasses. I don’t notice it on plates or mugs, but when I drink from a glass I always notice the very slight odour (unless I rinse the glass first under the tap). The dishwasher itself doesn’t smell and the only thing slightly out of the ordinary is that I place the Finish table in among the plates rather than the detergent compartment because more often than not the plastic door on the detergent compartment fails to open. Does any one have any ideas or suggestions?
    #152124
    Stop using tablets, we don’t like them much… issues. 😉
    What’s the odour like? Any film or discolouration on the glass?
    gegsy
    Re: Slight Odour Left on Glasses (Bosch Dishwasher)
    Them lemony dangly freshness things are devil for leaving this type of residue.
    Shaunf
    My wife put one of those lemony dangly freshness things in to try and get rid of the smell, but it didn’t work. There’s no film or discolouration on the glass and the odour is so slight that I can’t really tell what it smells like. I notice that the 1.5″ of water that gets left in the sump of the dishwasher (below the filter) is yellowish in colour and if I drain it out, then I don’t seem to get the odour on the glasses for several cycles.
    PS. Because the plastic door on the detergent compartment sticks, then I think our only option is tablets trown in with the plates at the start of the cycle.
    #152127
    gegsy
    Does empty hose go to sink spout?? and if so does the hose coil higher than the spout to stop backflow of sink water
    Shaunf
    The hose from the dishwasher is on the right hand side and comes up from the floor. The sink is on the left and the vertical pipe comes down from some vegetable washer thingy.
    #152129
    That’ll do it. Your waste is lower than the sink waste so basically waste water is going back into the dishwasher by the looks of that.
    Raise the drain hose a few inches. 😉
    Shaunf
    thanks kwatt, I’ve looped it up now so that the top part of the hose is much higher
    #152131
    bobokines
    If you are putting the tablet in the tub with the plates then it’s likely that the detergent is being washed away in the pre-rinse.
    You have two choices; either repair the dispenser or put the tablet in before the main wash cycle, not the pre-rinse. This entails opening the door during the wash which is not advisable. There are two reasons for this;
    1)The door switch is not designed to switch the heater current and therefore over a prolonged period the door switch could fail.
    2)The vacuum created by the action of opening the door can fool the water level system and cause fill problems.
    The dispenser not opening problem is usually the dispenser itself but it could be the control module at fault. It will need an engineer to check to be sure.
    Bob
    #152132
    Shaunf
    bobokines wrote:usually the dispenser itself but it could be the control module at fault. It will need an engineer to check to be sure.
    I know its not the control, its the latch mechanism that sticks.
    #152133
    Replacement dispenser complete is p/no 263088, about £32 +VAT etc. Alternatively, check http://www.bshappliancecare.com and follow links into Partfinder, the individual dispenser components can be identified and sourced there.
    bobokines
    Be very careful if you have a go at taking the dispenser out. The edges of the stainless steel door panel are razor sharp.
    Bob
    #152135
    gegsy
    bobokines wrote:Be very careful if you have a go at taking the dispenser out. The edges of the stainless steel door panel are razor sharp.
    Bob
    Not to mention a swine to push in (will become obvious), watch you dont bend the stainless door in the process
    Shaunf
    thanks all, I think the message here is call someone to do the job.
    #152137
    Shaunf
    Thanks to all your help I think I now know what the problem is. I tried throwing the tablet into the dishwasher just as the main wash was starting and the glasses came out without any trace of an odour. So it seems this problem was directly caused by the tablet getting washed away by the pre-wash. Then I took the cover off the dispenser and had a closer look inside. The dispenser itself and the latch looked fine (no signs of wear), but there seemed to be something broken off the cover. If I am lucky I hope the problem will be resolved when I buy a new cover. Thanks to you all for your help (and patience).
