smeg dishwasher DI612c
Viewing 11 posts - 16 through 26 (of 26 total)
  • #251157
    fasetester
    Re: smeg dishwasher DI612c
    i was talking to the woman today. and told her to put it throught the glass wash program. she said it will go through the program but the flap does not open and the dishes are not cleaned properly she said she tryed putting the soap in a cup i told her about five min after the program started to open the dishwasher and wait for it ot stop and trow a tablet in to see if it washes any better fasetester
    #251158
    Oldtog
    fasetester, you have asked a lot of questions here, I will try my best to answer.
    The solenoid is fed directly from the PCB, the PCB may not show signs of damage, normally it does not, if a component is failing or has failed you most probably would not be able to tell, unless you know how to read one of those tester thingies that puts the signal on the screen, this is then really high tech end stuff. There are those who enjoy bringing out all their gadgets and gizmoes for that sort of thing. The answer is, the PCB should be replaced.
    Next, the pressure switch, water can easily enter to pressure chamber and create problems. If you are so inclined, then remove the pressure switch and strip down, you would soon see if any water has entered the chamber, also check the contacts for burn marks where they make contact. I don’t bother with all that fuss, I replace, that way I know it will function as it should.
    As far as I am aware at this present time, the solenoid on the soap dispenser cannot be replaced without damage to the support unit for the solenoid, thus, the whole unit is to be replaced. However, I have never had cause to replace the soap dispenser in this model.
    I have said earlier this model has known issues with the PCB and pressure switch. If the solenoid does not open on the any wash, this is not going to be a cheap repair for your customer.
    It is one of those jobs if you have not come across it before you feel damned if you do and damned if you don’t, I have felt like that many times when I have received advice. The best thing you can do is advise your customer of the potential cost even if you are not successful, if they say OK regardless, then have that in righting from them so they cannot back track.
    Oldtog
    fasetester, Replace the PCB, it is the only way. Even P45 has said the pcb. Advise your customer of the potential cost, if they say yes then you are in profit with a happy customer.
    fasetester
    thanks again dave and chris for all your help. is the model number enought for ordering the parts the pcb and how much is the pressure switch. the only pressure sw i can see on servast is the round pressure switch what is the one like that goes in the sump what is QER like for repairing pcb fasetester
    #251161
    Oldtog
    fasetester, I now pass over to Chris, he is the whiz on parts and prices.
    Part number for PCB on previous page. I have had mixed experiences with QER, especially with BSH and SMEG boards. They hold no stock and will only try and repair your board. 50/50 shot, I’d say.
    Oldtog
    I have found delivery time 7-10 days, no real problem from Servevast. I think they give discount to non SMEG agents.
    PRESSURE SWITCH part number is 816210325
    I do not have any PCB boards repaired, I have new ones, that way any failure within a year it gets replaced FOC, I make sure they give a years GT on parts whom ever I purchase from.
    Spurs (good team the wife’s family supports Spurs)
    #251164
    fasetester
    thanks guys if the person goes for the repair the pcb does not need any setting up. and does it come in the white case i would say that the board should be handled as little as possible. fasetester.
    #251165
    Oldtog
    Yes comes in white cover, make sure you place all the wires in the correct terminals (silly to suggest I know but best to be sure). When fitted set to glass program, when full the machine goes into wash about a minute later the sop disp opens (providing you closed it before testing), about five minutes after that open door and make sure the flap has opened and the water feels warm, then write out your invoice and get paid, lovely jubly.
    fasetester
    thanks again for all your help dave i am waiting for servast to reply to my e mail fasetester.
    #251167
    fasetester
    dave the only give a six months guarntee on the pcb . when i told them i was a engineer and could carry out the repair to the proper standard the said the only give full 12 months to smeg trained engineers. what that all about thanks fasetester.
