Smeg DWI 710E
Viewing 8 posts - 16 through 23 (of 23 total)
  • #238097
    davemfox
    Re: Smeg DWI 710E
    Yippeee…just had a poke around some of the wiring, and look what appeared….
    Guess it was this that was being troublesome..
    Thanks for your help
    Re: Smeg DWI 710E
    Er, no, not exactly…..
    That’s the mains suppressor (a capacitance device 😀 ), which has undoubtedly blown and is responsible for the spurious flashing lights. The SMEG orginal component has been supeceded to one which requires major work to fit, so most of us are just using this:
    http://shop.ukwhitegoods.co.uk/product_ … cts_id=417
    With the addition of AMP tags to suit, it’s the same unit.
    The start/run capacitor is the cylinder attached to the side of the pump motor.
    davemfox
    Re: Smeg DWI 710E
    Crikey…wonder what else has broken on this machine then..:)
    AMP Tags? What’s that then??
    gegsy
    Re: Smeg DWI 710E
    davemfox wrote:AMP Tags? What’s that then??
    Greg 😉
    #238101
    davemfox
    Re: Smeg DWI 710E
    Thanks Greg… 🙂
    Penguin – well took the capacitor off the motor and it looks a bit knackered eh?
    Cheers,
    Re: Smeg DWI 710E
    Nice one. We can conclude that the component has failed……….
    Good luck with it, let us know when you get it going.
    davemfox
    Re: Smeg DWI 710E
    Got back today and fitted all the parts that had blown, and she’s working a good one now 😆
    Re: Smeg DWI 710E
    Well done.
    :p45:
