Smeg DWI710E1 4 to 5 hr to complete a wash
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg DWI710E1 4 to 5 hr to complete a wash
Viewing 14 posts - 16 through 29 (of 29 total)
  • #199277
    fasetester
    thanks eastmark for the reply their seem to be a lot of problums with blockages what side is the metering tank on what coil failures are we talking about what do you mean realy just off boiling water fasetester
    #199278
    fasetester
    hi guys went to see the smeg dishwasher today when put on would just keep the pump running removed from unit and tipped back no water came out as i thought the anti flood had actived the pump removed filter and cleaned under the little black flap tried again would start to fill then activate the pump checked metering tank could see the water come into the metering tank but when filled half way up would bring in pump water would go up one of the channels in the metering tank like a blow off on a centrial heating tank and dribble down is it the bribbling down that is keeping the pump running turned water off to releave pressure reconnected again but if i cut back on the water pressure went ok what is you thoughts thanks fasetester 😕 🙂
    #199279
    fasetester
    come on guys i want to hear you opion please fasetester 🙂
    #199280
    Lawrence
    Re: Smeg DWI710E1 4 to 5 hr to complete a wash
    From memory these don’t like high water pressure ,A while ago if you ordered a PCB it came with a valve restrictor !.
    Somtimes the tube behind the non return flap gets blocked and does wierd things .
    Lawrence
    #199281
    fasetester
    thanks lawrence for your reply where is the none return flap in the smeg even when i removed the main feed hose from the metering tank and put it in a dish the water would flow for a short time and then stop as i said it would run ok with the pressure turned down is it ok to leave the pressure turned down so that it runs thanks fasetester 🙂
    #199282
    Depending on software, these dishwashers either do a continuous pump with intermittent bursts of fill for a good 2/3 minutes before the fill proper starts or, the other version is intermiittent fill and intermittent pump for a few minutes. You need to let it complete this sequence before diagnosing the problem.
    What I meant by “just off boiling water” is really hot water but not quite boiling. 😉
    the non return valve is either in the pump outlet or in the inlet of the pump where it pushes into the sump.
    the Coil reference referred to the dispesner coil.
    Judging by your description its a classic E2 fault, remove the meetering tank/air break, its only 2 screws and the breather ring inside and give it a good clean, especially the passage through the softner which ends up at the flap at the back of the sump.
    #199283
    fasetester
    thanks eastmark for your reply so the smeg can fill and empy for 2 to 3 minutes before starting a programe so you have to wait before deciding if there is a fault should the householder not know that who is using the machine should the meetering tank when it is filling send some water up a channel like a blow off then like spit some water out of it and go down another channel the only way i could get it to work was cut back on the mains pressure so that it would fill and carry on the program the woman said it had not worked like that for a good while it would start and after a while stop and beep after i cleaned out under the black flap and checked the meetering tank for flow even when i removed the main hose to the meetering tank and let it flow into a basin the valve would activate and then stop after a min or so what is your thoughts on turning down the water pressure eastmark thank fasetester 😕 😳
    #199284
    fasetester
    woopps i nearly for got thanks k for the mail i though it was in my pm box but i tracked it down fasetester 😳
    #199285
    fasetester
    wel guys has any one any thing to add about the smeg dishwasher or turning down the water pressure thanks fasetester 🙂
    #199286
    Fase, you’ve got the tech info, you’ve got input from a number of people – now you have to sit down and work it out. Failing that, bring it to the next UKW meeting and we’ll have a session on it. Otherwise, do the honest thing by your customer and say “I can’t do it”. I’ve had to a few times, and the customer usually appreciates your honesty.
    fasetester
    sorry to get your beard in a blaze pen i have sorted the the dishwasher no call to lose your temper old man relax chill out fasetester and thank again for all your input. 😉
    #199288
    dpm
    So what’d you do then?
    #199289
    Yep, can you resolve the thread so that others in the future can benefit from your experience.
    #199290
    fasetester
    no problem guys first i turned off the power then i cleaned out the sump and cleaned under the little black flap turned off the water supply disconnected the the hose to release the pressure reconnected the hose turned down the water pressure going to the valve turned on the power run a program and it worked ok the customer was happy to hear it wash and that was that thanks all for the help another one for uk whitegoods fasetester 🙂
