Smeg SUK62MFX5 – Oven fault (will not heat)
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Smeg SUK62MFX5 – Oven fault (will not heat)
Viewing 2 posts - 16 through 17 (of 17 total)
  • #186530
    Garyu
    Re: Smeg SUK62MFX5 – Oven fault (will not heat)
    Hooray……a fixed Smeg SUK62MFX5 – thanks for your help Greg and Penguin45 🙂
    To summarise, these were the fixes:
    * There was a burnt out spade connector on the thermostat – it’s grip was very weak. When replaced the oven worked fine but overheated. I bought an oven thermometer from a Hardware store to confirm this – 100oC on the dial was 250oC on the thermostat….!
    * The burnt out connector melted part of the thermostat housing and in turn damaged the thermostat. I’ve replaced the stat (partcode was correct thanks!) – and everything works fine
    Please close this link – big thanks to Greg and Penguin.
    This service has been a great help and I’ve recommended it to others – thanks once again
    GaryU :colour:
    #186531
    gegsy
    Glad you got sorted :tup:
