Home › Forums › General Trade Forum › TDS……ARGH!!!!!
- This topic has 16 replies, 10 voices, and was last updated 13 years, 9 months ago by
robbra.
June 18, 2012 at 5:27 pm #70013
robbra
ParticipantHi all,
I have been using an old Vista laptop for this but it crashed so a factory reset and install but after trying most of the weekend on both this and my new Windows7 laptop it keeps saying ” a file missing” and I must have tried it seven or eight times on each. I even tried to do the 2006 version in desperation all to no avail.
I used it quite a bit so will miss it and my question is….has anyone got a copy on one of those pen drive USB thingys or any sure fire way of getting the disc to load. (I had this a couple of years ago and then one time it just loaded) I know it is the older version so installing it with XP.
Thing is on the old laptop it’s a couple of hours and finding it doesn’t work is a real bummer. 😥
Any help appreciated.
RobJune 18, 2012 at 6:47 pm #376754Hollytree_Technical
ParticipantRe: TDS……ARGH!!!!!
Do you have the access runtime installed?
Can you give us a screen shot of the error or any other information?
Is Microsoft Access Installed on the PC?
When is it crashing?I will start with those questions and go from there based on your answer.
Jem
June 18, 2012 at 7:24 pm #376755robbra
Jem, where do I start?
Don’t know what access runtime or MS accees are.
It doesn’t crash, just won’t run when loaded and the screenshot, no but will tell you the error when I restart the old’un but it takes about 20 mins to get going so will do that tomorrow.
Funny thing is it loaded about 2 years ago without those things unless they come annonymously with MS updates.
Will post the error code in the morning.
Thanks for answering.June 18, 2012 at 10:54 pm #376756stratfordgirl
Remember to install Adobe Reader first if not already installed. (old version on the TDS disc or later version from Adobe website)
June 19, 2012 at 5:56 am #376757robbra
Yes Adobe installed.
The message comes up.
” Adobe cannot open the file as it’s not a supported file or the file is damaged”June 19, 2012 at 8:25 am #376758Martin
If you can get it to work on Windows 7 then you are the man, you could plait sawdust, walk on water even.
June 19, 2012 at 9:45 am #376759Hollytree_Technical
I have it working on windows 7 (Professional 64 bit) so I know that it can be done.
Microsoft Access is a database program and is what is being used in the back end of the software.
This sounds like an issue with adobe reader:
Can you successfully open PDF files on the PC?
Try going to “C:Program Files (x86)ElectroluxTDS Offlinediagrams” and choose a couple of different sub folders to go into and then the next sub folders and try to open a couple of random PDFs to see if it will or not – this should tell us whether it is an adobe problem or TDS problem (Note: if you are running a 32 bit windows then it will be “Program Files” not “Program Files (x86)”).The one other thing that it might need though I am not yet sure is the microsoft dot net framework (not sure which version it would be but would guess 1 or 2).
Jem
June 19, 2012 at 10:07 am #376760electrofix
ModeratorRe: TDS……ARGH!!!!!
have no probs with xp or 7 works treat
i use the iso file of the disk and run it using Daemon Tools Lite ( from file hippo ) ( creates virtual cd drive )
that enables me to run the disk on 4 systems at the same time also since all files are on the hard drive access is very fast
June 19, 2012 at 10:48 am #376761Muv
ParticipantTDS……ARGH!!!!!
Maybe a daft question .. But want is, and where can I get TDS
LolJune 19, 2012 at 10:49 am #376762Muv
Want = what
June 19, 2012 at 2:00 pm #376763iadom
ModeratorTDS……ARGH!!!!!
You can’t, it was discontinued a couple years ago.
Sent from my iPad using Tapatalk HDJune 19, 2012 at 2:31 pm #376764kwatt
KeymasterRe: TDS……ARGH!!!!!
2008 I believe it was killed off.
June 19, 2012 at 2:43 pm #376765Muv
Ok, thanks…..
June 19, 2012 at 5:42 pm #376766BobHope
i have the issue 1 2009 version and it runs fine on windows 7, just make sure that all the service packs are updated and install it and the pdf files in a seperate directory on the hard drive, dont use the default directory. then if you still have problems (i dont), run the programme in one of the older compatability modes.
June 19, 2012 at 7:32 pm #376767Ralph
I’ve got in running on a Win 7 laptop, seem to remember having to make it run as XP in the options.. Would really be useful if it could run in Android though
Sent from my GT-N7000 using Tapatalk 2
