TDS Disc
Home Forums General Trade Forum TDS Disc
Viewing 4 posts - 16 through 19 (of 19 total)
  • #353504
    squadman
    Re: TDS Disc
    I was only loading because I have just done a windows install, took 4 hours in all. I’ve found a link on an old thread to the Electrolux site which seems similar to TDS so I’m getting a smartphone to check that when out and about and will persevere with the TDS later. I had Reader 10 running but it had a fault apparently so that may have a bearing.
    Rob
    Thats the thing with a windows install and getting the computer back to its last working state. With Acronis the recovery is very quick and sooner or later every windows system will require a re-install due to speed and booting issues. Adobe Reader 7.01 seemed to be the start of the TDS woes but by Ver 9 seemed able to work as already being installed when TDS was executed.
    The Galaxy is a great Tablet better then a smart phone but not so big as an I pad or as restrictive if you want a larger screen to work with.
    #353505
    wizard
    Re: TDS Disc
    I’ve been trying to get TDS 2008 to run on a new netbook. Managed to get the disc copied to a folder on the hard drive but unsure how to install. I remember having to put a “run” command in when I installed on the old laptop, but have lost the case the disc came in which had the instructions on. Anybody know what to do next ? Thanks, Wiz.
    #353506
    Re: TDS Disc
    wizard wrote:I’ve been trying to get TDS 2008 to run on a new netbook.
    you need a virtual disk programme i use “virtual cd v9” there are others. the programme creates virtual cd drives that you can load virtual cd into then run and install programmes just as if it was a real drive. you will need to create an iso copy of the cd on your hard drive but the prog can do this for you
    dave
    #353507
    wizard
    Re: TDS Disc
    Thanks Dave. I’ll have a go. Wiz
