Teba – Oven glass panel needed
Home Forums Public Support Forums Spare Parts Help Teba – Oven glass panel needed
Viewing 15 posts - 1 through 15 (of 18 total)
  • #6249
    I have accidentally broken the external glass panel on the front of my Teba black built in oven. Make – S0S60
    The glass panel measures: 570mm wide and 440mm high
    Can anybody help and let me know where I could get a new glass panel from?
    Thanks Laura
    #116558
    Laura,
    Dave Conway wil be able to advise you on this on Monday.
    Dave_Conway
    Re: Teba – Oven glass panel needed
    Laura.
    I got the helpdesk message you sent as well and replied to that before I had read this post.
    #116560
    I have a similar problem with my built-in oven. It’s a Teba model SOMF60SS A07.
    The removal inner glass panel shattered whilst being cleaned last week. I’ve spent the week trying to get hold of Teba to look into getting the replacement but it now turns out that they are in receivership and have no support team. No one else has a spare part in stock.
    The only advice I’ve received is to get hold of suitable glass, cut to size, and to slot this in.
    I have 2 questions:
    1. Do you know where I can get a spare?
    2. Can you advise on what glass I need and/or where to get it?
    Any help would be greatly appreciated as the oven is less than 2 years old and works perfectly otherwise.
    #116561
    hi
    Drop me a e-mail to r600a@hotmail.com with your full model number which will be on the top of your oven..you will have to take the oven out of its housing though and i should be able to help.
    bryan
    #116562
    I need a glass panel for the sos60 also. It has just shattered right through.
    #116563
    is this the inner or outer glass panel?
    we also need the full model number and serial number which is on the top of the oven.( you will have to remove the oven to obtain this )
    bryan
    #116564
    Its the outer glass panel that appears to be bonded to the stainless steel panel which has broken, the inner one is OK.
    I have removed the door and taken off the outer panel. I assume this comes as a complete part : the glass bonded to the steel ?
    The data from the panel on the top is:
    TEBA SOS60SS (TFA10-31Y)
    PRODUCT NR. TFA 10 GBR 34
    #116565
    Dave_Conway
    Luckily both the versions of this have the same outer door glass, part number is 03794H08.
    Hopefully Bryan will be able to supply as no-one else will be able to I don’t think at the moment 🙁
    #116566
    Is it bonded to the steel then?
    #116567
    BobHope
    HI
    Yes it is all one part,
    if Brian does not reply give Dave a shout and and i am sure we can sort you out, but teba glass parts dont travel well in the post so what is your location or post code.
    Cheers Bob.
    #116568
    St Helens Bob. Will either of these contact me shortly?
    #116569
    BobHope
    Yes they will both very reliable 🙂
    Cheers Bob.
    #116570
    excellent, thanks muchly
    #116571
    hi
    email me your details to r600a@hotmail.com and i should be able to help.
    i will need your full model number and serial number which can be found on the top of the appliance which you will have to remove to get.
    bryan
