TOC for Hotpoint WD640
Viewing 10 posts - 16 through 25 (of 25 total)
  • #302476
    helo_75
    itll be the fluff filter
    remove it and snip the wire to the valve.
    problem solved
    and will help your statory rights
    fit for purpose and all the usual nonsense people use
    #302477
    kwilby
    helo_75 wrote:itll be the fluff filter
    problem solved
    Hi helo, that sounds wonderfully simple but I’ve no idea where this filter is or what it looks like. Can you give me a clue please?
    I really appreciate your patience 🙂
    #302478
    kwilby
    Re: TOC for Hotpoint WD640
    Surely somone knows where this filter is? 😕
    #302479
    Its a very small, mesh filter at the back of the heater box, It has thin grey plastic hose connected to it.
    #302480
    kwilby
    iadom wrote:Its a very small, mesh filter at the back of the heater box, It has thin grey plastic hose connected to it.
    Thank you! I had to remove the heater box flange from the top of the drum (as well as splitting the heater box) to get to this filter.
    At first look it seemed OK but it turned out to be covered with a fine film of lint. I cleaned it and put it back in as I was rather nervous to “remove it and snip the wire to the valve” as advised earlier.
    I replaced the thermal cut-out (again) and all seems well, although I don’t think I’ll be using the high temp setting as it was doing this that caused the last cut-out to, erm, cut-out 😆
    Thanks again to all who helped.
    #302481
    helo_75
    i ALWAYS remove the filter
    works so much better, and the toc never trips again
    good luck
    #302482
    kwilby
    helo_75 wrote:i ALWAYS remove the filter
    I’m up for following your advice but I was a bit concerned by the wire snipping aspect, ie which wire to snip and could I achieve the same aim by removing the connector from the valve.?
    #302483
    helo_75
    same thing
    fill yer boots, itll dry soooooooooo much better
    #302484
    kwilby
    helo_75 wrote:same thing
    OK that’s my Saturday job sorted 🙂
    Thanks.
    #302485
    kwilby
    I thought I’d provide an update on this. I did as helo_75 suggested back in 2009 and the machine has been working perfectly ever since, so many thanks for sharing your experience there helo_75 🙂
