Tricity Bendix dishwasher bizzare problem (not heating)
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Tricity Bendix dishwasher bizzare problem (not heating)
Viewing 15 posts - 16 through 30 (of 32 total)
  • #176387
    justinbarrow
    Re: Tricity Bendix dishwasher bizzare problem (not heating)
    when i first bought the dishwasher i was told that i wouldnt need much salt wether that means we have hard water or not im not sure.
    Can these chambers be blocked so hard, it looks like white plastersine in the bottom of the chamber.
    Right, off back to it see whats what, if only you could remove the chamber without having to take eveything off
    Thanks again
    #176388
    Dave_Conway
    Try this
    Descaler
    #176389
    justinbarrow
    cheers dave, but the machine wont fill with water or heat, but pumps out.
    still trying to get this white stuff out of the chambers, do you think with the dishwasher only running cold hasnt helped as this helps fat and greese set.
    can this stuff realy be hard as plastic? thought it may have been gungy but not hard.
    blowing through the pipes underneath is not helping either
    cheers
    justin
    #176390
    Dave_Conway
    The hard substance is limescale by the sound of it, hence my suggestion of descaler 😉
    #176391
    justinbarrow
    right i have disconected the clear tub from the spigot under the sump also done the same with the red clear tube, put a container under the machine and got someone to pour water into both chambers and i get water comming through the 2 bottom spigots where the transparent hoses attach so seems it is not blocked.
    Only thing now is i have 2 blue tubes one is longer and slightly bigger hole and ive forgot which way they should go? 🙄
    Before i pored the water through i pulledof the clear transparent pip from underneath and when doing so heard the pressure switch click, so seems to be looking up.
    #176392
    justinbarrow
    Well cleared it all out got water going through the 2 spigots under the sump where the blue tubes are and have refitted the smaller tube to the flood protection (the left of the chamber) and the longer blue tube to the pressure switch side (clear thin tube) the right side of the chamber container.
    Then it started to fill with water and then it sounded like it stopped (about 30 seconds in) but could hear water like it was still running into the machine in fact thats exactly how it sounded just like water flowing underneath like it was leaking but seemed quieter than a normal fill. also when it first takes water it is making a sound like a fridge generator starting up, I also noticed this sound when it first broke.
    Could this now be a faulty inlet valve as i have tested the pressure switch (3 pin type) and when gently blowing it opens and closes as it should. I have also noticed on the pressure switch that when the machine does not let any water in and is making the leaking sound that the pressure switch is switched to kick in the heater but the terminal to the grey wire to the inlet valve is open (no juice). When i test the pressure switch across the 3 terminals with the wires connected i get a continuity buzz across all 3 terminals but not when the cable are disconected from the switch (is this normal)
    I will try for another day then get some one to it, i hope its not timer related. Got some numbers of the site so will get on with that in due course. Im thinking it may be something like timer (expensive part) and with call out charges on top feel it may not be worth repairing.
    Thanks guys,
    Justin.
    EMAIL: justin.realsoundproductions@virgin.net
    —– Original Message —–
    #176393
    gegsy
    When you are doing your fault finding, I hope you are remembering to unplug your appliance prior :tup: Heaven forbid anything should happen to you 😉
    justinbarrow
    cheers it is powered off, but it is becoming a headache now.
    Does anyone know of anything else it could be? thanks
    Justin
    #176395
    Justin,
    Short blue tube goes in the left hand slot and feeds to the pressure switch. Long blue tube goes to the right and feeds the pneumatic shut off on the inlet valve. If reversed, the machine will fill once and stop filling on the shut off rather than the pressure switch. As a result, the next fill…. won’t.
    justinbarrow
    this is how i have done this as you look into the dishwasher where the dome is that houses the blue tubes i have done…
    Small blue tube to the left and the longer/bigger tube into the right of the chamber.
    from under the machine it looks like the right chamber feeds the pressure switch (clear thin tube) and the left chamber goes to the thin red tube which goes to the water inlet valve.
    I have tried it the other way round but find that one tube doesnt sit properly into the left chamber.
    Would you now suspect this is timer related if still dont get any joy.
    I have got a local appliance shop that says if i take the water inlet valve off they will test it, would they have a more accurate test metre than a normal standard one.
    Thanks again.
    Justin
    #176397
    gegsy
    Hi Justin,
    This appears to be more than basic fault. Mr P has given you some good advice but Im beginning to think its time for and engineer and admit defeat. Most faults we can sort, some like yours are more intense and would really need us to be physically there to diagnose.
    In fairness aswell, If you have no facility to even cold test a valve then we reallyaren’t going to get far are we.
    If you need an engineer please look at the link below.
    Regards
    It sounds like the air hoses are reversed. Short tube is for the pressure switch, so air hose should be connected to the left hand spigot. Long tube operates the pneumatic shut-off – air hose should be connected to the right hand spigot.
    There is nothing wrong with your inlet valve – you know that it will fill the machine. Solenoid coil valves work or they don’t – there is very rarely a half way stage.
    justinbarrow
    Thanks, the air pipes were the wrong way round i did have the blue tubes in the right way but i had the red and clear tubes the wrong way. So now i have the the tubes underneath as follows…
    Red tube (to water inlet) To the left side of the chamber
    Clear Tube (To the pressure Switch) To the right side of the chamber
    Previous to this i had them the oposite way round., I wouldnt of damaged it any further i hope, what an idiot i am 🙄
    I have also taken the motor,drain pump,pressure switch out and took this to NW VACS (local white goods engineer) and he tested everything and said it was fine. So i am hopeing that I did have a bloackage and it was me not remembering where the hoses went underneath and put them back the wrong way that has cause the machine to halt after filling, would the timer stop running if this was the case?
    Thanks Mr P, Dave and Gegsy!
    I just hope when ive put everything back together that i have hot water 😆
    Justin
    #176400
    justinbarrow
    well, sorted the water inlet problem now the pipes are the right way round, but still no heat.
    I hope i have put the element wires on the right way, lol
    Power is going to the element but it will not heat, 24olms is what i get on the continuity.
    So i think i will be investing in a new one, never though something could go in this way, I may donate it to the local college electrical course say here you go sort this one 😛 Again the machine is going through everything it should now aprt from heat, and the timer gets stuck on hot rinse. but should get hot through the normal wash
    Spoke to an enginner here (NW VACS) and they said low budget dishwashers are to throw away as most of the time the cost of parts out weighs the cost of a new one,
    Thanks for all the help, really apriciated and i hate to admit defeat on this but if it has to be.
    Any last min ideas would be great – thanks again everyone.
    Fantastic site
    Justin
    #176401
    justinbarrow
    Just seen a Tricity Bendix DH090 for sale would this be ok to get and strip my old DH086 (the one that wont heat) for spares.
    My question is how different is the dh090 to the DH086 just notice that the timer dial is different.
    Are the motor, pumps etc the same
    Justin
