Troubleshooting an oven – running out of ideas
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Troubleshooting an oven – running out of ideas
Viewing 15 posts - 1 through 15 (of 18 total)
  • #102898
    Mark Flint
    The oven is a Rangemaster Classic Toledo 110 Dual Fuel. The problem is that the fan oven trips the RCD after about 5-10 mins of heating from cold.
    Things I have done to troubleshoot:
    1) visual inspection of wiring – nothing obvious
    2) take the fan motor out of circuit (disconnect) – RCD trips
    3) take the lamp out of circuit (disconnect) – RCD trips
    4) take the thermal fuse out of circuit (short) – RCD trips
    5) take the thermostat out of circuit (short) – RCD trips
    6) take the element out of circuit (disconnect) – RCD does not trip
    7) run the oven with power to the element but with the oven door open so that temperature does not rise much – RCD does not trip
    So, it seems to be related to temperature of the oven, but it still happens with the thermal fuse is shorted out, and the thermostat is shorted out.
    Any suggestions for next step?
    Thanks, Mark
    #490951
    Serial number please?
    Kentish
    Have you metered or meggered the elements?
    Seen so many ovens of all makes tripping when hot, especially with air fryers being so common
    #490953
    as Kentish says its most likley the element
    Mark Flint
    kwatt wrote:Serial number please?
    Serial number 7321 158184.
    #490955
    Mark Flint
    Kentish wrote:Have you metered or meggered the elements?
    The client replaced the element him self. Both the new one and the old one meter at 22 ohms.
    #490956
    Mark Flint
    electrofix wrote: as Kentish says its most likley the element
    The client replaced the element him self before calling me out. How often would a new element be faulty I wonder – I suppose it could happen.
    #490957
    was it gen or pattern
    I dont trust pattern parts these days in elements, too many failures
    gen element part no A094693
    #490958
    Kentish
    i never trust anything a customer fits, as most likely it’s the cheapest they can find.
    Its not the resistance of the element, but it’s resistance to earth. Everything you have said points to an insulation breakdown, and whilst a good multimeter would show it(my old Fluke went to 500meg ohm on resistance, a megger would show it more easily even when cold.
    #490959
    Lawrence
    Its the element going down to earth, I bet the customer bought a pattern one of the web, I have stopped using pattern elements for that reason, the fact that when you disconnect the element it doesnt trip tells you everything, test it with the back off and as soon as it trips megger the element from either of the terminals to earth, I bet it will be low resistance, then watch as it cools down it will come back in to range
    #490960
    Mark Flint
    electrofix wrote:was it gen or pattern
    Thanks Dave, I appreciate the part number.
    #490961
    Mark Flint
    Lawrence wrote:Its the element going down to earth
    Thanks Lawrence. It might be time to buy a megga, my DMM is not up to some of these tasks.
    Mark
    #490962
    Mark Flint
    Yes, a genuine part will now be fitted.
    Thanks, Mark
    #490963
    Kentish
    Thanks, Mark
    Before you do, I would get a decent DMM with or without insualtion testing (up to 1000v) or buy a stand alone insulation tester.
    You cannot test safely and with certainty without it/them.
    I myself have a Fluke DMM, which is fantastic but getting long in the tooth.
    I also have a Fluke DMM with insulation test that goes up to 2gig.
    I also have a stand alone Fluke insulation tested that runs to 11gig.
    My prefered options are the first and last, but weight saving means I only carry the middle one in my tool bag
    #490964
    Mark Flint
    Thanks for the advice, I’m planning on getting a stand alone megga.
    Mark
