Ultima WD865 Woes
Viewing 15 posts - 1 through 15 (of 18 total)
  • #17025
    jamesw
    My Ultima was making helluva noises during spinning and draining. Switshed off, took the drain pump and the drain hose off. The filter in the drain hose was absolutely full of stuff ( a sock, some underwire from a bra, enough loose change to buy a few pints, must learn to check the pockets better). Anyway, I cleared this out, reassembled. The machine now spins and drains silently, but the dryer doesn’t work.
    It goes through the motions, the condenser takes water in, th etimer counts down, but there is no heat at all. Does anybody have any idea what I might have broken? I’d like to try and fix it myself before calling out the pros.
    James
    #172601
    Dave_Conway
    Re: Ultima WD865 Woes
    This thread will help, pretty much the same machine 🙂
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=13541
    #172602
    jamesw
    Thanks Dave for the quick response. I can only see one heater element when I remove the back (or should I say the little inspection panel, as the whole back doesn’t come off), does this do both drying and washing ? (In any case this element heats up, as I confirmed with a 95 degree wash).
    If I knew where the thermostat was I could check it, although I still think I’ve probably dislodged a wire somehow.
    James
    #172603
    The dryer heating element is on top of the drum, encased in a metal ducting. The advice given in the link that Dave provided is spot on.
    There has been a full modification of the whole of the dryer heater assembly on this machine. If you do not change it you will have persistant problems, changing the stat is not a cure, only a temporary fix.
    What is the Date Code (first two numbers of serial number) of your machine?
    #172604
    jamesw
    iadom wrote:What is the Date Code (first two numbers of serial number) of your machine?
    Thanks, the first two digits are 35
    #172605
    Modification was from Date Code 40, so you do need the full kit to effect a proper repair.
    #172606
    jamesw
    Thanks for the advice, the stat has definitely gone OC. So where do I get the full kit from.
    Cheers
    #172607
    Part number is 1605230, e mail to spares@ukwhitegoods.co.uk should do the trick. 🙂
    #172608
    jamesw
    Thanks for all for the help. Email has been sent.
    #172609
    jamesw
    Thanks for the expert remote diagnosis. Part arrived today, fitted and all is well. 😀 Great service all round.
    Of course you didn’t tell me I’d have to drill a whopping great hole in the body to take the filter, or that my cables would be too short with the mod. 😉
    James
    #172610
    johnnyj
    Fitting the 1605230 heat box you also need to remove filter, remove wiring suppying vlave to filter etc etc,
    #172611
    jamesw
    johnnyj wrote:Fitting the 1605230 heat box you also need to remove filter, remove wiring suppying vlave to filter etc etc,
    Oh….
    so I’ve left mine in – is this going to be a problem.
    #172612
    It could be, the filter has been removed to improve the air flow over the element. Unless they include specific instructions to do so , no drilling etc is required when fitting Hotpoint parts/modifications.
    I will e-mail you ASAP. 😉
    #172613
    Dave_Conway
    I think johnny refers to having to remove them to gain access/fit only rather than remove them completely 😀
    #172614
    Dave_Conway wrote:I think johnny refers to having to remove them to gain access/fit only rather than remove them completely 😀
    No, they should be removed completely, and discarded.
    All these instructions are normally included with the parts. ❓
