Very old junior
Viewing 10 posts - 16 through 25 (of 25 total)
  • #314699
    Re: Very old junior
    Alex wrote:Que Martin…
    Your spelling was always rubbish Alex… 😉
    Besides,….Cor blimey guv,… don’t remind me of the 3224 Keymatic right now as the scars haven’t had time to heal. 😛
    Going back to getting the “beats as it sweeps” brush bar out of a 1334 for a moment….If the belt is broken (so you can’t use the ‘Alex method’) simply remove the front cover and clout the brush roller with the wooden end of a hammer! 😀
    And to remove that bottom right hand motor fixing screw, there was a ‘cut away’ in the metal body to allow this access. Simply fold down the pink (yes pink – or an odd shade of red anyway) rubber furniture guard. Refitting the motor housing I found it best to insert the screw into it’s hole in the housing first, then offer it into place before finally screwing it (if you catch my drift?).
    What else?…..Oh I know, re-wiring the terminal block was always a challenge for many (workshop trainees) as they always disconnected those in-line suppressor and field coil terminals without noting which terminal went where? Putting the wrong wire in the wrong spot and then plugging it in was always a source of laughter in our workshop when all the lights in the building went out!…oh how we laughed!!
    And when they changed the wiring design to a thru-terminal suppressor in the 1346E, well that did fox many when it came to putting it all back together.:rotl:
    Happy days indeed!
    P.S In the photo you gave us of your example of the 1334 madrat…..Does it have that all important pink rubber furniture guard (cos it ain’t in the photo’s?) I think if it had one and was in good nick then it would treble or quadruple the value of the whole appliance!
    #314700
    madrat
    Re: Very old junior
    The belt isn’t broken but it looks like the original 1958 model 😯 I don’t think it would take much pulling. It looks like 100s of little bits of rubber connected with tiny bits of hair.
    No the rubber furniture guard is missing, and I can only find replacements in gray, but it will match the bag, What was the colour of the original bag?
    #314701
    Re: Very old junior
    Brown, grey or blue.
    Re: Very old junior
    madrat wrote:What was the colour of the original bag?
    As your example shows the original front plate with the red bakelite on/off switch and the pink handle bail release lever I would say without much doubt that the original bag was red.
    #314703
    madrat
    Re: Very old junior
    should look like this then.
    Dont think I will be able to get it back to that.
    #314704
    madrat
    Re: Very old junior
    OK I have re fitted the bag with twine and changed the alignment slightly.
    On removing the brush roller and end caps I was presented with this.
    The belt had defiantly been around for a few years. It wouldn’t even turn the roller.
    Reassembled and she is sucking like new.
    As I will never get her back to original condition I dont know whether to pimp her up a bit. 😕
    #314705
    Re: Very old junior
    madrat wrote:As I will never get her back to original condition I dont know whether to pimp her up a bit. 😕
    Well if you can get hold of a replacement furniture guard, then a clean up the metal body + a re-spray, then it’s is a worthwhile venture I would say. 😀
    Go on, pimp those wheels!!!!!! 8)
    #314706
    madrat
    watch this space in the better weather.
    #314707
    madrat wrote:watch this space in the better weather.
    Bloody Nora!….hasn’t your workshop got a roof on it then? 😆
    #314708
    madrat
    You must be joking, After fitting out my workshop with electric and work benches it was appropriated by wife and kids for there junk!
