Re: Washer Heaters
Only ever changed the heater if the rubber grommet is perished, all others fit in nicely, then again we are in a soft water area down here.
This scenario could be applied to so many things though, best not reuse the backplate after fitting new bearings, it might not be flat and could leak or fracture, same as rear half drum, soap and sump hoses, changing the carbons and not the holders, door seals without changing the clip that holds it on, the list could go on!
I think its a case of deciding whats best when in site, no correct way and no wrong way and we can all recall something bad happening when we didnt do something that some one else would have done!
Sent from my iPhone using Tapatalk
