WD-12801T LG 2007 tripping breaker when door is closed
Home Forums Public Support Forums Help And Support Washing Machine Help Forum WD-12801T LG 2007 tripping breaker when door is closed
Viewing 2 posts - 16 through 17 (of 17 total)
  • #471555
    does sound likely
    your getting 560,000 ohms on a 9v meter. if you used a 500v insulation tester it would be lower
    on the face of it, it looks like you have a faulty motor
    M00se
    can i just plug it directly to the mains the same as i would with an induction motor ? is it as easy as putting mains voltage to the brush terminals and letting it rock and roll ?
