WDD960GUKC water issue
Viewing 3 posts - 16 through 18 (of 18 total)
  • #459357
    my normal joke to customers is ” I make it a point never to die till I have been paid “
    you can blow into this type of switch its the later type that you cant test and gets wrecked by too much pressure
    right if the unit is still filling when you switch it off then its either a board or valve issue
    if its a valve issue then if you pull the plug it will keep flowing till you turn off the taps
    so it sounds like a board issue. it may just be a leaky triac which are cheap and easily changed if you can solder electronic components
    Claudiagomez
    Are you still in the same situation?
    https://financepolice.com/
