Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › What are the best quality bearings and where do you buy ’em?
- This topic has 20 replies, 9 voices, and was last updated 17 years, 8 months ago by
leavemetogetonwithit.
February 7, 2009 at 4:17 pm #259715
ParticipantRe: What are the best quality bearings and where do you buy
eastlmark wrote: I think the poised question should be: what are the best quality bearing seals and where do you buy?
The spider may also have a bearing on this. I often receive Hotpoint ones which have very tiny dents or scratches in the brass bit. No attempt seems to be made to protect this important surface by some manufacturers. I wonder if they send us the rejects.
Mike.February 7, 2009 at 7:42 pm #259716maltheviking
leavemetogetonwithit wrote:Can anyone tell me why some makes and models have a bleed hole for water to escape, e.g. Hotpoint WM, whilst some don’t e.g. Zanussi split tubs.?
Mike.Most seals use water as their lubricant (unlees they are greased). Better to let any water that does get past the seal to escape than damage the bearing.
February 7, 2009 at 8:31 pm #259717Turbo
Have been using bearing seal lubricant for a number of years now but not sure if it makes the job last any longer though. Did get a call back to a WM 62 a couple of years ago complaining that the machine was noisey after my drum bearing change 😥 turned out to be not enough seal lubricant in the seal lip 😥
GrahamFebruary 7, 2009 at 9:03 pm #259718leavemetogetonwithit
maltheviking wrote: Most seals use water as their lubricant (unlees they are greased). Better to let any water that does get past the seal to escape than damage the bearing.
Yes but that doesn’t explain why Zanussi don’t do it. I’m wondering if they work on the theory that the air trapped behind the seal would, by its pressure, impede water ingress. ❓
Mike.February 7, 2009 at 9:09 pm #259719Simon46
Isnt Yurtesen the expert on this :rotfl:
http://www.ukwhitegoods.co.uk/modules.p … t=yurtesenFebruary 8, 2009 at 12:17 am #259720Penguin45
Aaaaaaaargh…….. *Looks for “You’re barred” button…….*
:p45:
