whirlpool 3LWED4815FW thermostat
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts whirlpool 3LWED4815FW thermostat
Viewing 15 posts - 1 through 15 (of 17 total)
  • #103143
    deltra
    hi all,looking for the 2 thermostats that sit side by side on top left on heater baffle,they look to be same size,cant see any info on connect or elsewhere!! any help appreciated. did find part c00508901, 1 thermostat looks correct,not sure that other one is correct.
    #491934
    these units are american maytag machines
    https://www.partadvantage.com/modelp…d/3LWED4815FW0
    Aswo has part diagrams as well as the above stat kit in stock
    deltra
    thanks dave:)
    #491936
    deltra
    hi,im back with this dryer,that part has only one thermostat on the bracket,the one i need has 2 thermostats on one bracket at top left of heater.sorry dont know how to post pics.
    #491937
    there is a double stat but its on the output and not on the heater box. its on the duct after the fan
    deltra
    That might be the thing,1 is o/c. Bypass it and heater comes on. Have you a part number Dave
    #491939
    finding the American version is easy
    https://www.partadvantage.com/wpl-wp3387137.html
    its converting to a uk number thats a pain
    connect list as no longer available 5045177159545
    but that will probably only ally to the uk as its in stock state side
    well after a bit of digging and a help from a friend got
    481928248311
    c00311682
    deltra
    it does havw w10916382, 300f stamped onto bracket, but i cant tie that in with anythibg:mad:
    #491942
    ok try
    C00519613
    Aswo list but 7 to 8 weeks lead time
    washingmachinewoman
    Appears to have been superseded by 482000098399
    Quinnspares has it in stock
    https://www.quinnspares.com/products/482000098399.html
    #491944
    deltra
    That’s the beast:p thanks very much for your help,both.
    #491945
    deltra
    back again:rolleyes:fitted stat,ran good for 15 min then blew again:o no blockages,any ideas??? will have to buy another… cant reset these……any wiring diagrams i can try to work out temp values. thank you.
    #491946
    is that stat von the side of the element ?
    deltra
    yes dave it sits on side of element at top.
