Re: Whirlpool 997 bearing replacement
No, not usually a case of tightening. When shoving the back plate into the tub, the sealing gasket will almost always get dislodged from the edge of the back plate and have to be relocated before fitting the clamp band. Slip the back plate back, ensure all surfaces around the edge of the tank are spotlessly clean and that the gasket is fitted to the edge of the back plate correctly. When fitting the clamp band, you should finish up with a gap of about 1/4 – 3/8″ between the ends as a rough guide when fully tightened.
If it really won’t seal, spares@ukwhitegoods.co.uk will be able to supply a new tub gasket. It’s worth getting a tube of Debor sealant/adhesive at the same time. Sticks anything to everything and seals it, too.
My Mrs would have removed important parts of my anatomy by now, BTW – you’ve had three weeks to sort this out! 😀
Stay safe – power off.
